Topic: Cutting A Breadboard In Half? (Read 9070 times) previous topic - next topic
evilcubed
I am using a solderless breadboard with my arduino uno for a project but i want to make the breadboard about the same size as my arduino. Can i cut it widthwize and still have it work?
be80be
It would be easier to buy a small one. But I solder headers on mine and my buddy atom cut one in half long ways
evilcubed
i couldnt find any smaller breadboards :P So if i just cut the breadboard in half, can i just solder the loose ends and cover it with electrical tape and it would work?
MichaelMeissner
Adafruit, among other sellers sell smaller breadboards, such as: http://www.adafruit.com/products/65 and http://www.adafruit.com/products/589.
I bought some proto-shields that the small breadboard fits in: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=93.  This is useful in that I can do a project on one shield, take off the shield and put on another without having to undo the wires.
At some point, I will probably move to the proto-screwshield so that I can use the screw part to connect wires for remote sensors: http://www.adafruit.com/products/196.
be80be
http://adafruit.com/products/65?gclid=CLTimZTbtLQCFQsGnQod4gMA2Q
There every where, But if you cut down a row of pins you shouldn't have to solder any thing.
evilcubed
OK thanks for your help? I just meat I didn't wanti the hassle of buying it online haha
MichaelMeissner
I should mention, this is what a breadboard looks like inside (I had glued it down, and then tried to remove the breadboard):
cjdelphi
I once watched a video of someone using an actual breadboard, trying to remember where i saw it  :smiley-eek-blue:
http://www.youtube.com/watch?v=HrG98HJ3Z6w
ahh Collin, i've watched all of his video's, if you happen to read this Collin, PLEASE MAKE SOME MOREEEEEEE :)
fungus
I don't see why not...
I don't think there'll be "loose ends". I'd use epoxy glue or something, tape will come off.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
MarkT
Use a fine hacksaw, it will cut any metal parts nicely as well as the plastic.  Have the backing layer uppermost so
the that the saw teeth don't try to pull it off.
