Topic: [documentation] BUS I2C (Read 5767 times) previous topic - next topic
chabot380
Bonjour
De la doc sur le bus I2C ici : http://www.aurel32.net/elec/i2c.php
bonne lecture.
chabot380
Ubuntu16.04
ARDUINO UNO / Atemga2560pro / Arduino Nano
Technicien Télé Vidéo à la retraite.
jhdscript
nolimit60
Bonsoir chabot380,
J'ai trouvé dernièrement ce lien PDF:
http://artic.ac-besancon.fr/genie_electronique/telech/sonde/i2c.pdf
A+
fdufnews
#3
Jan 12, 2013, 07:15 pm Last Edit: Jan 28, 2013, 03:48 pm by fdufnews Reason: 1
Un petit programme qui scanne le bus à la recherche des éléments connectés.
Code: [Select]
// Wire Scanner
// Demonstrates the use of the Wire library
// Ping all valid adresses on the I²C bus
// and get the answer to see if there is a slave
// Print an 8 x 16 array with the results
// Created by fdufnews 2012 december 14th
// This example code is in the public domain.
#include <Wire.h>
 Wire.begin();         // join i2c bus (address optional for master)
 Serial.begin(9600);   // start serial for output
 Serial.println();     // Print a banner
 Serial.println("I2C slave scanner");
 Serial.println("   reserved adress");
 Serial.println(".  no slave detected");
 Serial.println("X  slave detected");
 int result;
 Serial.println("   0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F");
 // Scan only valid addresses (8 to 0x7B)
 // 0-7 and 7C-7F are reserved ones
 unsigned char devices=0;                  // holds how many devices found
 for (unsigned char ad=0; ad<0x7C;ad++){
   if(ad%16==0){                           // If at start of a row
     Serial.print(ad>>4,HEX);              // Display high order bit address
     Serial.print(" ");
   if (ad>7){                              // skip address from 0 to 7
     Wire.beginTransmission(ad);           // start transmission
     result = Wire.endTransmission();      // end transmission and store answer
     if (!result) devices++;               // add a device to the count if ACK
     Serial.print(" ");
     Serial.print(result==0?"X ":". ");    // If ACK there is a guy at this address
   else{
     Serial.print("   ");                  // Sorry nobody here
   if(ad%16==15) Serial.println();         // end of the row add a new line
 Serial.print(devices, DEC);
 Serial.print(" device");
 Serial.print(devices>1?"s":"");
 Serial.println(" found on the bus");
john_lenfr
Un petit programme qui scanne le bus à a recherche des éléments connectés.
Code: [Select]
// Wire Scanner
#include <Wire.h>
  int result;
      Serial.print(" ");
      Serial.print(" ");
    else{
Nikel ce pti code, merci beaucoup ;)
jhdscript
