Topic: Arduino Ethernet failed to work - upload/bootflash did not work (Read 648 times) previous topic - next topic
tkampp
Hello,
Since yesterday I've got some problems with my Arduino Ethernet. I hope somebody can point me to some new direction about what to try or can tell me when there is no hope for this instance anymore. I made a brief summary of what I already tried, if there are any gaps, I'd happy to fill them in.
Synopsis:
- Arduino Ethernet runs 24x7 since February 2012 with minor downtimes (e.g. some minor patches of the sketch). Attached to it was a one-wire-bus and a xbee connected via SoftwareSerial (i.e. not on rx/tx), network connectivity was regulary used to push data.
- Arduino Ethernet connected via Usb2Serial Light on a Windows 8 64bit system
- After trying to upload an updated sketch it fails with: "ser_send(): write error: sorry no info avail"
- Futher attempts to upload this sketch and a simpler one (e.g. Blink) lead to the following error message: "avrdude: stk500_getsync(): not in sync: resp=0x00"
- Starting the board simply results in a glowing Power LED and the L9 LED, Reset button has no visible effect
Attempts to save "something":
- Tried uploading from a different system (WinXP, 32bit) -> same
- Tried the loopback test http://arduino.cc/forum/index.php/topic,73748.0.html -> successfull
- Read a lot of stuff about 0x00 and ...
- Tried to flash the bootloader with a working Arduino UNO as described here: http://arduino.cc/en/Tutorial/ArduinoISP
C:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/bin/avrdude -CC:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: Recv:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
- Since this didn't work, I tried to flash the bootloader with Optiloader like this: http://scuola.arduino.cc/en/content/upgrade-arduino-ethernet-bootloader-latest-version. Sadly this only led to the message "Target power on! ...No RESET pullup detected! - no target?" and stopped.
Any idea what I could try besides this? Is there anything deducible what might have caused this?
Thank you very much in advance.
Kind Regards,
Thorsten
