Topic: Arduino Due and ADK 2012 (Read 41769 times) previous topic - next topic
Palliser
DO NOT connect directly your speaker to the DAC pin.
Please, read and follow the following updated tutorial.
http://arduino.cc/en/Tutorial/SimpleAudioPlayer
Regards!
andreuc
C:\ADK2012_IDE_0/hardware/tools/adk2tool.exe COM3 erase
erasing...done.
C:\ADK2012_IDE_0/hardware/tools/bossac.exe --port=COM3 -w -b C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build5785210613214747736.tmp/Arduino_Terminal_App_Sample.cpp.bin
No device found on COM3
C:\ADK2012_IDE_0/hardware/tools/adk2tool.exe COM3 reset
resetting...done.
Guys, I'm trying to use a MEGA ADK and I arrived at the same point: troubles  in  detecting the MEGA on the COM. Any suggestions?
tnx!
a
newhobby
andreuc
andreuc
@newhobby, connecting the MEGA ADK using  native usb, windows doesn't see anything on the usb. Is there any driver to install to make the pc see the port?
newhobby
I think you are in the wrong thread.
This is for a Due board and not Mega.
Also, maybe you ought to start with blink code before you start trying to use Goodle ADK stuff.
andreuc
I'm sorry but i didn't found any mega adk thread. If you know where is it, would you be so kind to tell me? No problem with adk 2011 so far, but as i read through the forums adk 2012 is not so immediate.
Thanks
Andrea
atoy40
Hello,
i'm trying to use a Due with a Nexus4 phone. I've compiled an loaded the sample successfully (thanks to your code modifications tips  :)), but when i plug the Due on the Phone, the phone battery charge status start to blink, and i get a repeated "disconnected" message in the arduino serial console. (the phone detect an adk accessory sometimes, somtimes not...)
I use a USB-A female <-> micro-B male on the phone side (not referenced as OTG), is it a problem ?
Another question, has anyone tested a blutooth shield on the Due ? and the ADK2-over-BT feature ?
Thanks.
Anthony.
Yoshi0351
#53
Oct 13, 2013, 06:32 am Last Edit: Oct 13, 2013, 06:34 am by Yoshi0351 Reason: 1
Have you tried using an external power source? I was fighting trying to get this to work with my Galaxy S4,  had no luck til I plugged in a wall wart.
I am using an OTG adapter though...
atoy40
Yes, i've tried this weekend with a power supply and it's now working perfectly :D
brnyza
#55
Feb 10, 2014, 07:27 pm Last Edit: Mar 19, 2014, 02:40 pm by brnyza Reason: 1
Hi all,
I've tried this example and it worked:  http://arduino-er.blogspot.com.br/2013/04/arduino-due-android-adk-change-led.html?view=classic
Is this example use "ADK 2012"?
Just another question, someone know what's the advantage to use processing (http://stream.tellart.com/controlling-arduino-with-android/)
Someone built the communication of Arduino due + Android app developed with processing?
Thank you.
Processing + Eclipse + Android + Arduino Due (USB and adk.h)
The video example working: http://goo.gl/FGmYLe
based on example: http://android-er.blogspot.com.br/2013/03/adk-example-control-arduino-due-led.html
Phone: 4.1.2 GT-S6812B
destroyer85
And add an ifdef on the USBCore.cpp to disable the CDC code.
Code: [Select]
#ifdef USBCON
Original USBCore.cpp code goes inside the ifdef. I can't add or the post is too long and exceeds the maximum allowed length of forum, which is 9500 characters.
#endif // USBCON
Hello and thanks to everybody in this thread now i'm able to upload a working sketch to my arduino that can communicates with my android mobile phone. I have one question about programming arduino DUE. Until now i was able to upload working sketch only with native port. i read that there is a solution to use the programming port and the native port. I unaderstand almost everything escept the part tha i quoted. Anybody can explain me this part?
Thanks in advance.
bt_noobie
Hi everyone!
Thank you to everyone in this thread. Special thanks to ardroid.
I have finally made arduino due usb audio work.
I would like to make BT audio work too. Has anyone here succeeded on it?
Google's adk2012 was using custom ckt and stack with TI cc2564. It's not available in the country I'm in and it's also smd which is difficult for me to solder some pins into.
I tried using HC-06 but it only supports serial communication.
If you were able to succeed BT audio, could you share what BT module or chip you used and some code maybe?
