Topic: Connecting Two Microcontrollers Via Serial RS232 (Read 2096 times) previous topic - next topic
chiques
What are the key factors I need to consider when connecting my Mega to a Mcu sending a stream in RS232 format?
This code is not streaming text in my serial window when I run it so I'm trying to figure out what the problem might be.
http://atlas-scientific.com/_files/code/Arduino-sample-code-EZ-COM.pdf
Here is my unit:
http://atlas-scientific.com/product_pages/embedded/flo-30.html
Thanks for any help.
Osgeld
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
chiques
Code: [Select]
This software was made to demonstrate how to quickly get your Atlas Scientific product running on the Arduino platform.
An Arduino MEGA 2560 board was used to test this code.
This code was written in the Arudino 1.0 IDE
Modify the code to fit your system.
**Type in a command in the serial monitor and the Atlas Scientific product will respond.**
**The data from the Atlas Scientific product will come out on the serial monitor.**
Code efficacy was NOT considered, this is a demo only.
The TX3 line goes to the RX pin of your product.
The RX3 line goes to the TX pin of your product.
Make sure you also connect to power and GND pins to power and a common ground.
Open TOOLS > serial monitor, set the serial monitor to the correct serial port and set the baud rate to 38400.
Remember, select carriage return from the drop down menu next to the baud rate selection; not "both NL & CR".
String inputstring = "";                                                       //a string to hold incoming data from the PC
String sensorstring = "";                                                      //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false;                                          //have we received all the data from the PC
boolean sensor_stringcomplete = false;                                         //have we received all the data from the Atlas Scientific product
  void setup(){        //set up the hardware
     Serial.begin(38400);                                                      //set baud rate for the hardware serial port_0 to 38400
     Serial3.begin(38400);                                                     //set baud rate for software serial port_3 to 38400
     inputstring.reserve(5);                                                   //set aside some bytes for receiving data from the PC
     sensorstring.reserve(30);                                                 //set aside some bytes for receiving data from Atlas Scientific product
   void serialEvent() {                                                         //if the hardware serial port_0 receives a char
               char inchar = (char)Serial.read();                               //get the char we just received
               inputstring += inchar;                                           //add it to the inputString
               if(inchar == '\r') {input_stringcomplete = true;}                //if the incoming character is a <CR>, set the flag
  void serialEvent3(){                                                         //if the hardware serial port_3 receives a char
              char inchar = (char)Serial3.read();                              //get the char we just received
              sensorstring += inchar;                                          //add it to the inputString
              if(inchar == '\r') {sensor_stringcomplete = true;}               //if the incoming character is a <CR>, set the flag
void loop(){        //here we go....
  if (input_stringcomplete){                                                   //if a string from the PC has been recived in its entierty
      Serial3.print(inputstring);                                              //send that string to the Atlas Scientific product
      inputstring = "";                                                        //clear the string:
      input_stringcomplete = false;                                            //reset the flage used to tell if we have recived a completed string from the PC
if (sensor_stringcomplete){                                                   //if a string from the Atlas Scientific product has been recived in its entierty
      Serial.println(sensorstring);                                            //send that string to to the PC's serial monitor
      sensorstring = "";                                                       //clear the string:
      sensor_stringcomplete = false;                                           //reset the flage used to tell if we have recived a completed string from the Atlas Scientific product
graynomad
From that Atlas link
Quote
Simple RS-232 connectivity (voltage swing 0-VCC)
They obviously have no idea what RS-232 is. They are using async serial but not RS-232. Lucky for you because the RS-232 voltage levels could blow up the Arduino.
I'm not overly familiar with serialEvent() but I think the code looks OK. What about your wiring and terminal setup?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
robtillaart
#4
Dec 27, 2012, 04:38 pm Last Edit: Dec 27, 2012, 05:05 pm by robtillaart Reason: 1
Quote
from HardwareSerial.cpp
Code: [Select]
void serialEventRun(void)
#ifdef serialEvent_implemented
 if (Serial.available()) serialEvent();
#endif
#ifdef serialEvent1_implemented
 if (Serial1.available()) serialEvent1();
#endif
#ifdef serialEvent2_implemented
 if (Serial2.available()) serialEvent2();
#endif
#ifdef serialEvent3_implemented
 if (Serial3.available()) serialEvent3();
#endif
called from main()
Code: [Select]
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USB.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
Not a "multitasking background event" but checked once per loop and it won't interfere with your loop code ..
Never used it, as it gives no clue about the amount of data available --> http://arduino.cc/forum/index.php/topic,139353.msg1046447.html#msg1046447
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
chiques
OK, it sounds like there is something funky going on with the manufacturer's code.
I guess I'll start something new using the Serial Library just to read the data stream coming in from the Atlas board. I'll post my results to conclude the thread.
Thanks for all your feedback.
PaulS
Quote
But you are, of course, free to call Serial.available() to learn that.
chiques
OK, problem solved. I don't know what I did different this time around to make it work but here is what I changed
1. I have an Arduino Uno and an Arduino Mega 2560. The Mega seems to be working now (I see streaming data on the serial port)
2. I connected both grounds on the FLO-30 controller
