Topic: AMIGA 500/1000/2000 Keyboard Interface (Read 83183 times) previous topic - next topic
yserra
To all of you who arrived here to connect an Amiga 500/1000/2000/3000/4000 keyboard to an USB port on a modern PC/Mac/Raspberry Pi/whatever computer:
The Olaf-DrRemulak Arduino Leonardo script discussed here is quite obsolete now, since it missed the simpler functions from the Keyboard.h Arduino library, that are especially done for the purpose to convert old keyboards to USB ones.
Here is attached a better script from Janne Lof (I can't find anymore its original link on Internet, sorry).
I confirm this one works well with my A1000 keyboard and should work with all other Amiga keyboards with a controller onboard (so, all Amiga keyboards except the ones from A600 and A1200). I added a 'delay(300)' in the Caps Lock handling subroutine to make the caps lock comptatible with MacOS computers (and it still works with other computers).
herregaarden
Thank you yserra, this works great on my A500 keyboard with a leonardo. Could never get the older scripts to work properly.
The only thing i can't get working is the 2 joystick ports, i have tried with retropie and fsuae on linux, but i can not see the ports
polymorph
That's awesome! I would like to build an Amiga laptop using a Raspberry Pi, and it will be great to be able to use an actual Amiga keyboard. Of which I have many.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
fidelware
#93
Aug 02, 2020, 08:29 am Last Edit: Aug 02, 2020, 10:46 pm by fidelware
Hello, first of all thank the people who have made this project possible.  has someone designed a STL case for PRINT it?
yanluowang_666
#94
Sep 07, 2020, 08:23 pm Last Edit: Sep 08, 2020, 02:51 pm by yanluowang_666
Hello,
I wanted to do the amiga keyboard interface with one arduino pro micro.
I made the pcb and bought all the components. I used @yserra code (sketch_clavier_amigav3.I no", but when I insert the code inside the arduino software, I always have error on the code. If someone can help me?
For more information, i did this :
https://www.pcbway.com/project/shareproject/Amiga_2000___3000___500_Keyboard_USB_adapter.html
I ordered pcb and all components.
fudmana
#95
Sep 26, 2020, 02:20 am Last Edit: Sep 27, 2020, 02:32 am by fudmana
Made some Changes to the Pos #87 code (tried to repair)
Got Amiga 500 keyboard and and both of joy ports working.  (In Windows)
Now I can make RPI and Amiga 500 keyboard working system :)
(Amiga 500 case is still in transport :s )
RickMK
#96
Oct 19, 2020, 02:42 pm Last Edit: Oct 19, 2020, 03:59 pm by RickMK
Keyboard not working for me and it's making my proper pc keyboard output mixed commands..
Pi can only see one joystick, windows can see two. not sue if its a name conflict on the pi ?
Will, investigate a bit more later...
BrainSlugs83
FYI, I rewrote the original code (fixing several bugs that are present in both this version and that version).
For example the handshake delay is wrong in both (waaaay too high, even according to the Amiga HRM). -- And they both handle the number pad wrong.
Additionally, I added Bluetooth support on ESP32 devices.
I chose to base it off of the original version since it was more portable (e.g. it used actual pin numbers instead of the raw PORT values). -- It's still super responsive on both the Leonardo/Pro-Micro and on ESP32s devices.
Code is here: https://github.com/BrainSlugs83/Amiga500-Keyboard/blob/main/AmigaKeyboard.ino
chiark
Thanks, that works really well!  The only thing I have changed is the key mappings - however I realise this is personal preference!  One thing I couldn't get working was for KEY_RIGHT_GUI to act as the right windows key (menu key). I guess sending a shifted F10 is almost the same...
MisterFPGA, which I'm using this with, needs F11 and F12 so I'm tempted to map HELP to F12, too.
kar1os
#99
Dec 30, 2020, 03:08 am Last Edit: Dec 30, 2020, 03:23 am by kar1os
Hi Guys - thanks for all the info. I've got my Leonardo ready to go but I can't for the life of me get Flip to connect to it so I can switch it into keyboard mode.
I keep getting the dreaded Atlibusbdfu.dll not found error.
The device driver for the board is loaded and it won't let me change it for the one in the flip/usb folder - looks like an error due to it being x64 Windows 10.
Any ideas would be appreciated. Cheers
** It's a keyestudio Leonardo r3 board - if ayone could suggest a better board then please do :)
