Topic: Bootloader programming with MKii (Read 435 times) previous topic - next topic
sharklaser
Dec 27, 2012, 11:36 pm Last Edit: Dec 27, 2012, 11:43 pm by sharklaser Reason: 1
Hi all,
Im using avrdude to install a bootloader but first need to erase the current chip
im using this command
avrdude -c avrisp2 -p m328p -e -P usb
and getting the following back
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_command(): unknown status 0xc9
avrdude: stk500v2_program_enable(): cannot get connection status
avrdude: initialization failed, rc=-1
        Double check connections and try again, or use -F to override
        this check.
avrdude done.  Thank you.
2 Green lights are on the mkii
Any suggestions ?
edit:
the light nearest the USB cable flashes green multiple times when the command is run, The side nearest the chip flashes red very quickly and then back to green - dont know if that helps
sharklaser
http://imageupper.com/g/?S020001008Y1356694282257167
For some images of it.
