Topic: Suggestion for where to buy arduino related products (Read 4719 times) previous topic - next topic
sasorhitomo
Hello,
I was a newbie for the arduino, usually like to do some small projects. When i first come into contact with the open hardware and the arduino, i was immediately attracted by its strong function and easy to use. now i want to start a project with arduino, so i would like to ask you generally where to buy the electronic products related to the arduino(I located in Japan, and i was a student, so the budget has a little bit nervous )? Thanks!
eried
My website: http://ried.cl
barak
#2
Dec 30, 2012, 03:40 am Last Edit: Dec 30, 2012, 11:35 am by Massimo Banzi Reason: 1
seeedstudio really is a famous company in open hardware community, and recently, i came across a store (link removed by admin) occasionally when i finding the Fusion PCB service. Its products is similar to the seeedstudio but the price is lower.
michaelshiloh
sasorhitomo,
Welcome to the wonderful world of Arduino. There is much to explore.
To find Arduino resellers, you might start here:
http://arduino.cc/en/Main/Buy
About 2/3 of the way down the page you will find the following, with links:
Japan: MechaRoboShop, Switch Science, Strawberry Linux, Techand, MicroFan, Kyohritsu, TechShare, Androciti
There are probably many other resellers as well.
Good luck and let us know what you build!
Michael
sasorhitomo
I think seeedstudio is a trusty/cheap store.
Thank you eried! I have see the seeedstudio, its products are complete.
sasorhitomo
Thank you! but i can't see the link..
sasorhitomo
sasorhitomo,
Michael
yeah, my classmate's arduino UNO was bought from arduino.cc.
bperrybap
For low cost small quantity components I like these guys:
http://www.taydaelectronics.com/
leds, resistors, caps, transistors, diodes, shift registers, temperature ICs, crystals, etc...
For sensor modules,  shields, lcds, etc.. I usually use ebay.
--- bill
barak
#8
Jan 04, 2013, 04:34 am Last Edit: Jan 04, 2013, 04:40 am by Coding Badly Reason: 1
To avoid the suspicion of advertising... just search (removed by a moderator) in the google
Coding Badly
Incorrect.  The link was removed because the vendor is blatantly violating the Arduino trademark.
