Topic: An LED flash question! (Read 902 times) previous topic - next topic
nicc
How do I flash an LED on for 100ms and off for 3000ms without using delay?
Thanks in advance.
marco_c
Look at the blink without delay example.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
JimboZA
But you'll need to think about how to have two different intervals for on = 100ms and off = 3000ms. As that example stands, the led is off and on for the same interval...
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
nicc
Could someone point me in the right direction. I have uploaded the blink without delay, but cannot see how to get the 'short on' and 'long off'
tack
You'll need to keep two delays, timers and a state record
E.g.
delayBlinkOn
delayBlinkOff
timerBlinkOn
timerBlinkOff
stateBlinkOn
stateBlinkOff
1) Turn your LED on and set stateBlinkOn to True and timerBlinkOn to the current millis().
2) While stateBlinkOn is true then you want to check timerBlinkOn each loop until it's equal or greater than millis() + delayBlinkOn.
3) Once the condition is met, turn your LED off and set stateBlinkOff to True and timerBlinkOff to current millis().
4) While stateBlinkOff is true then check the timerBlinkOff each loop until it's equal or greater than millis() +  delayBlinkOff.
5) Once the condition is met, you're back to turn your LED on at Step 1 above and the sequence repeats.
Now, go code that up. ;-)
AWOL
All you need to do in the blink without delay is change the value of "interval" when you change the LED state.
