Topic: LSR sketch (Read 2539 times) previous topic - next topic
sokbok
Hello. I am going through the GETTING STARTED WITH ARDUINO book and there is an example using a Light Sensitive Resistor and inputing that info into an analog pin to vary an LED brightness.
When I do the sketch, the LED only varies slightly. I would like it to go all the way out and back up if possible.
Here is the code Im using, directly from the book:
// Example 06B: Set the brightness of LED to
// a brightness specified by the
// value of the analogue input
const int LED = 10;
int val = 0;
// the pin for the LED
// variable used to store the value
// coming from the sensor
pinMode(LED, OUTPUT); // LED is as an OUTPUT
// Note: Analogue pins are
// automatically set as inputs
val = analogRead(0); // read the value from
analogWrite(LED, val/4); // turn the LED on at
// the sensor
// the brightness set
// by the sensor
delay(10); // stop the program for
// some time
ANY HELP APPRECIATED
billroy
It seems the range of your input values may not be driving the full range of output values.
Here's something I'd try.  First, do an experiment: print out "val" and see what values it assumes for the range of light your application needs.  Read up on the map() command in the reference and use map() to map the input range to the output range 0..255 -- in place of analogWrite(…, val/4);
Good luck with your project,
-br
nickgammon
@sokbok: Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Also don't double-space your code like that, it isn't an essay.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
