Topic: rgb led strip help (Read 3806 times) previous topic - next topic
koteman
i just got the rgb 1m strip from radio shack today and its controlled with 12v grd and data. i have the example sketches from radioshack but i just want to control a single segment that i cut of the end and be able to change the colors with a pot and turn it on and off with a push button how do i do this im very confused.
larryd
Do you have a Link for us so we can look at the product?
No technical PMs.
The last thing you did is where you should start looking.
johnwasser
It's a bit confusing.  If I understand correctly you can only control the strip in sets of three LEDs.  There are 10 sets in a 1m strip.
Each set receives 24 bits. The 1 bits are long (a little more than a microsecond) and the 0 bits are short (about half a microsecond).  Looks like the off time is not significant.
Send 24 bits for as many sets as you want to control.  I would expect the data to get shifted through so the first bits go to the furthest set and the last bits go to the nearest set.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
koteman
im just trying to figure out how to control one section of 3 leds to just stay one color and change with a push button or turning a pot and have a off position thats it. can anyone help me with this please. I tried using the switching method but it wont work it only changes on one end of the pot for a small area.
this is what i have so far
Code: [Select]
/******************** (C) COPYRIGHT 2012 RadioSHack ********************
* File Name          : strip.pde
* Author             : TRS
* Version            : V1.0
* Date               : 27/04/2012
* Description        : Main program body
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, RS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#include <avr/pgmspace.h>
// ******** DEBUG ==== should auto config to adapt different mother board *********
//#define DATA_1 (PORTF |=  0X01)    // DATA 1    // for ATMEGA
//#define DATA_0 (PORTF &=  0XFE)    // DATA 0    // for ATMEGA
//#define STRIP_PINOUT DDRF=0xFF  // for ATMEGA
#define DATA_1 (PORTC |=  0X01)    // DATA 1    // for UNO
#define DATA_0 (PORTC &=  0XFE)    // DATA 0    // for UNO
#define STRIP_PINOUT (DDRC=0xFF)    // for UNO
PROGMEM const unsigned long pattern_test_red[10][10]={
  {0x0000ff}
PROGMEM const unsigned long pattern_test_blue[10][10]={
  {0x00ff00}
PROGMEM const unsigned long pattern_test_green[10][10]={
  {0xff0000}
const int analogInPin = A1;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output for color
// *                            Power Up Init.
  STRIP_PINOUT;        // set output pin - DEBUG: should auto detect which mother board for use
  reset_strip();
  //noInterrupts();
// *                            Main Loop
  // read the analog in value:
  int sensorValue = analogRead(analogInPin);
  // map it to the range of 8 colors:
  int outputValue = map(sensorValue, 0, 1023, 0, 3);
  switch (outputValue) {
  //off
    case 0:
   send_1M_pattern(pattern_test_red, 1, 10);
//red
  case 1:
   send_1M_pattern(pattern_test_green, 1, 10);
//yellow
  case 2:
   send_1M_pattern(pattern_test_blue, 1, 10);
//green
  case 3:
frame++;
    if(frame<=10) LEDSTRIP_PATTERN_0();
    if(10<frame<=20) LEDSTRIP_PATTERN_0();
    if(20<frame<=30) LEDSTRIP_PATTERN_0();
    if(frame>30) frame=1;
  //delay(1);
* Function Name  : send_1M_pattern
* Description    : Transmit pattern to whole 1 meter strip
* Input          : pointer to ROM pattern; pattern length; frame rate
* Output         : None
* Return         : None
void send_1M_pattern(const unsigned long data[][10], int pattern_no, int frame_rate)
  int i=0;
  int j=0;
  uint32_t temp_data;
  for (i=0;i<pattern_no;i++)
    noInterrupts();
    for (j=0;j<10;j++)
      temp_data=pgm_read_dword_near(&data[i][j]);
      send_strip(temp_data);
    interrupts();
    delay(frame_rate);
* Function Name  : send_strip
* Description    : Transmit 24 pulse to LED strip
* Input          : 24-bit data for the strip
* Output         : None
* Return         : None
void send_strip(uint32_t data)
  int i;
  unsigned long j=0x800000;
  for (i=0;i<24;i++)
    if (data & j)
      DATA_1;
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      DATA_0;
      DATA_1;
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      __asm__("nop\n\t");
      DATA_0;
    j>>=1;
* Function Name  : reset_strip
* Description    : Send reset pulse to reset all color of the strip
* Input          : None
* Output         : None
* Return         : None
void reset_strip()
  DATA_0;
  delayMicroseconds(20);
medpixman
Take a look at this program: http://pastebin.com/wUSVNubd
This is too large for this forum - It is as fully functioning UNO program for the RadioShack RGB LED strips, using A0 as the output pin (there is a comment for changing the output pin).  There are several patterns added to the "stock" program:
Cylon
Trek Bridge
Red-White-Blue Chaser
Red-White-Blue Building Up
Comments, suggestions, corrections, improvements are most welcome.
