Topic: Iron man helmet faceplate and LED (Read 9027 times) previous topic - next topic
digitalfa
Hey guys i'm new to the Arduino and i have a Arduino Uno and i don't know how to write the code.
Can some pro please write me a simple code which turn 180 to open up the faceplate and LED turn off with a press of a button, then if press again it will turn back 180 counter clock wide to close the faceplate then turn on the LED.
johnwasser
#1
Jan 12, 2013, 12:28 am Last Edit: Jan 12, 2013, 12:32 am by johnwasser Reason: 1
Code: [Select]
const int servoPin = 2;
const int buttonPin = 3;
const int LEDPin = 4;
#include <Servo.h>
Servo visorServo;
  visorServo.write(0);  // Initial position
  visorServo.attach(servoPin);
  pinMode(buttonPin, INPUT_PULLUP);  // Connect button between pin and GROUND. LOW when pushed.
  pinMode(LEDPin, OUTPUT);
  digitalWrite(LEDPin, LOW);  // LED off
  static unsigned long lastPushedTime = 0;
  static boolean visorClosed = true;
  static boolean lastButtonState = HIGH;
  boolean newButtonState = digitalRead(buttonPin);
  // If the button is down and it has been a while since it was last down...
  if (newButtonState  == LOW && lastButtonState == HIGH && millis() - lastPushedTime > 100) {
    lastPushedTime = millis();
    if (visorClosed) {
      visorServo.write(180); // Open visor
      visorClosed = false;
      digitalWrite(LEDPin, HIGH); // Turn on light
    else {  // Viso is open
      visorServo.write(0); // Close visor
      visorClosed = true;
      digitalWrite(LEDPin, LOW); // Turn off light
  lastButtonState = newButtonState;
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
PeterH
johnwasser
tcengs
thread back from the dead, i am starting a similar project and the code provided works wonders , however i am trying to include a 2nd servo that moves in the opposite position as the 1st servo. i am new an dont know where to start. didnt mean to high jack
johnwasser
It's not hard to add a second servo:
Code: [Select]
const int servo1Pin = 2;
const int servo2Pin = 5;
#include <Servo.h>
Servo visorServo1;
Servo visorServo2;
 visorServo1.write(0);  // Initial position
 visorServo1.attach(servo1Pin);
 visorServo2.write(180); // initial position
 visorServo2.attach(servo2Pin);
   if (visorClosed) {
     visorServo1.write(180); // Open visor
     visorServo2.write(0);
     visorServo1.write(0); // Close visor
     visorClosed = true;
tcengs
its been 15 years since I've written code. Thanks for the quick reply
arielcosco
como hago para que el servo suba despacio en la apertura?
Phop
Sorry to ask but im not good with any of this bought a kit cant work it out but can follow a diagram, would some one be able to post one of how the board would be set up
cedarlakeinstruments
Besides the fact that you're dredging up a 5 year-old thread, what kit? what board? Set up for what?
Electronics and firmware/software design and assistance. No project too small
Phop
So at the top of this post is a sketch for a iron man helmet. I want to know how to set up the breadboard and how to wire it up
xl97
Have you done a search?
This topic has been posted before..
Also.. maybe check out:  www.therpf.com  where prop makers hang and show their work..
many diagrams and code there for this type of project.
Phop
Hi pal already found your post followed and build thanks for that helped loads. Just came across this first and asked the question but sorted thank to you cheers
herbertvwright
#13
Aug 29, 2019, 01:18 am Last Edit: Aug 29, 2019, 01:20 am by herbertvwright
Is the helmet connected via USB? The helmet shell itself is a slightly modified model from Thingiverse, the LED eyes are inspired by another persons project but the motor setup, hinge design, remote control and arduino code is all my own.
