Topic: Compiling error: 'bye dns[]' declared as different kind of symbol (Read 4716 times) previous topic - next topic
0bl1vion
Jan 14, 2013, 11:34 pm Last Edit: Jan 14, 2013, 11:36 pm by 0bl1vion Reason: 1
I am trying to build an automated watering system for my lucky bamboo plant. I am playing around with the original source code and have ran into a peculiar error. I have done quite a bit of googling and have come across a few discussions that suggest it may be an IDE related error.
Syntax reads:
Code: [Select]
sketch:51: error: 'byte dns[]' redeclared as different kind of symbol
\arduino-1.0.2-windows\arduino-1.0.2\libraries\Ethernet/Dhcp.h:64: error: previous decleration of '<anonymous enum> dns'
I tried running this code in IDE versions 1.0, 1.0.1, and 1.0.2 - the two earlier versions come out with a different kind of error. I've tried replacing the Ethernet library on 1.0.2 with an earlier version but that did not work. So I am sure there's gotta be something wrong with the code. Any ideas?
Code: [Select]
#include <Ethernet.h>
#include <SPI.h>
#include <aJSON.h>
#include <SimpleTimer.h>
 Pin configuration
int moistureInputPin = 0;
int moistureOutputPinTop = 2;
int moistureOutputPinBottom = 3;
int valveOutputPin = 9;
 How often to check the plant needs watering
 and to send readings to the server
unsigned long pollMillis = 60000; // 1 min
 How dry the soil should get before watering.
 (Max) 1023 = Drier than the Atacama Desert
       400  = Damp
 (Min) 0    = Have you used copper instead of soil?
// Watered value = 75-76
int waterAtMoisture = 1023 - 400;
 When the soil gets dry enough to warrant a watering,
 how many millis to open the valve for.
int waterForMillis = 3500;
 Cube Server IP
byte server[] = { 23, 21, 244, 111 };
 Local IP settings
byte mac[] = { 0x6E, 0x58, 0xB8, 0x2F, 0xF7, 0x89 };
byte ip[] = { 192, 168, 2, 20 };
byte subnet[] = { 255, 255, 255, 0 };
byte gateway[] = { 192, 168, 2, 1 };
byte dns[] = { 8, 8, 8, 8 };
EthernetClient client;
SimpleTimer timer;
 pinMode(moistureOutputPinTop,OUTPUT);
 pinMode(moistureOutputPinBottom,OUTPUT);
 pinMode(valveOutputPin, OUTPUT);
 Ethernet.begin(mac, ip, dns, gateway, subnet);
 Serial.print("My IP address: ");
 Serial.println(Ethernet.localIP());
 timer.setInterval(pollMillis, poll);
 timer.run();
 Main function that is run once per poll
void poll() {
 Serial.print("Polling... ");
 //Using int for watered rather than boolean
 //as the cube server doesn't report metrics
 //on booleans very well
 int moisture = getSoilMoisture();
 int watered = 0;
 Serial.println(moisture);
 if(moisture > waterAtMoisture) {
   waterThePlant();
   watered = 1;
 postToServer(moisture, watered);
 Drives a current though two digital pins
 and reads the resistance through the
 analogue pin
int getSoilMoisture(){
 //Drive a current through the divider in one direction
 digitalWrite(moistureOutputPinTop,HIGH);
 digitalWrite(moistureOutputPinBottom,LOW);
 //Take a reading
 int reading = analogRead(moistureInputPin);
 //Reverse the current
 digitalWrite(moistureOutputPinTop,LOW);
 digitalWrite(moistureOutputPinBottom,HIGH);
 //Stop the current
 return reading;
 Gives the plant a two second blast of water
void waterThePlant() {
 digitalWrite(valveOutputPin, HIGH);
 delay(waterForMillis);
 digitalWrite(valveOutputPin, LOW);
 Posts a JSON document to the cube server
 (see http://square.github.com/cube/)
 The JSON document describes the soil
 moisture and whether the plant was
 watered.
   "data": {
     "moisture": 600,
     "watered": 0
 Using int rather than boolean for 'watered'
 as cube metric querying is limited with booleans
void postToServer(int moisture, int watered) {
 while(!client.connected()) {
   client.stop();
   Serial.println("Connecting...");
   if (client.connect(server, 80)) {
     Serial.println("Connected");
     Serial.println("Connection failed");
     delay(5000);
 aJsonObject* rootJson = aJson.createArray();
 aJsonObject* event = aJson.createObject();
 aJson.addItemToArray(rootJson, event);
 aJson.addStringToObject(event, "type", "moisture");
 aJsonObject* data = aJson.createObject();
 aJson.addItemToObject(event, "data", data);
 aJson.addNumberToObject(data, "moisture", moisture);
 aJson.addNumberToObject(data, "watered", watered);
 char* moistureJsonStr = aJson.print(rootJson);
 client.println("POST /1.0/event/put HTTP/1.0");
 client.println("Content-Length: " + String(strlen(moistureJsonStr)));
 client.println("Connection: keep-alive");
 client.println();
 client.println(moistureJsonStr);
0bl1vion
I should also mention that I tried changing 'dns' to another name, but the (aJson) library I am using starts generating multiple other errors.
DVDdoug
I would assume dns is delcared already in <Ethernet.h>, and it may not be a type byte.  You should research that and check some examples rather than randomly "hacking" or guessing/assuming.  ;)
I've forgotten the exact syntax for initializing an already declared array, but you might be able to simply drop "byte" from that statement.  i.e. dns[] = { 8, 8, 8, 8 };
0bl1vion
Thank you for your input!
I am a complete newbie when it comes to programming..so this is pretty difficult at this stage of the game hehe
What do I need to look for to tell if dns is defined in the Ethernet.h file? If I change or remove 'byte,' IDE gives the declaration of array error.
This is my Ethernet.h
Code: [Select]
#ifndef ethernet_h
#define ethernet_h
#include <inttypes.h>
//#include "w5100.h"
#include "IPAddress.h"
#include "EthernetClient.h"
#include "EthernetServer.h"
#include "Dhcp.h"
#define MAX_SOCK_NUM 4
class EthernetClass {
private:
  IPAddress _dnsServerAddress;
  DhcpClass* _dhcp;
public:
  static uint8_t _state[MAX_SOCK_NUM];
  static uint16_t _server_port[MAX_SOCK_NUM];
  // Initialise the Ethernet shield to use the provided MAC address and gain the rest of the
  // configuration through DHCP.
  // Returns 0 if the DHCP configuration failed, and 1 if it succeeded
  int begin(uint8_t *mac_address);
  void begin(uint8_t *mac_address, IPAddress local_ip);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway, IPAddress subnet);
  int maintain();
  IPAddress localIP();
  IPAddress subnetMask();
  IPAddress gatewayIP();
  IPAddress dnsServerIP();
  friend class EthernetClient;
  friend class EthernetServer;
extern EthernetClass Ethernet;
#endif
PaulS
Quote
What other name? What other errors? The name "dns" is local to your sketch. You should be able to change it to anything you want.
