Topic: TX command code & RX respond code of module via serial com (Read 17601 times) previous topic - next topic
mr_hacker90
hi everyone. i have a question here. i need to sent 8 bytes command code to a fingerprint reader. and then, read the 6 bytes respond code of the reader. sending & reading the code is via serial (RX & TX). i already made the code. but, it is not working. i just want to ask your opinion what's wrong with my code here. seems that the TX & RX LED even not light up when i start the program. thank you.
Code: [Select]
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8,9,4,5,6,7);
byte addFingerPrint[] = {0x4D, 0x58, 0x10, 0x03, 0x40, 0x00, 0x00, 0xF8};
byte respond = 0;
 // initialize serial:
 Serial.begin(57600);
 // set up the LCD's number of columns and rows:
 lcd.begin(8, 2);
 displayLCD();
 addFinger();
 correctRespond();
void displayLCD(){
 // set the cursor to column 0, line 1
 lcd.setCursor(0, 0);
 // Print a message to the LCD.
 lcd.print("Reader");
void addFinger(){
 lcd.setCursor(0, 1);
 // print the number of seconds since reset:
 lcd.print("Add");
 // print the string when a newline arrives:
 Serial.write(addFingerPrint, sizeof(addFingerPrint));
void correctRespond() {
 lcd.print("Cor");
 if (Serial.available()) {
 // read the most recent byte
 respond = Serial.read();
 // print the correct respond code of the reader (0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7)
 lcd.print("Cor=");
 lcd.print(respond, HEX);
PaulS
How many characters of the reply are you reading? How long are you waiting for the reply?
quertyn
#2
Jan 15, 2013, 11:54 am Last Edit: Jan 15, 2013, 11:58 am by quertyn Reason: 1
First thing in your code, in correctRespond function you should poll until the fingerprint reader sent back a response, just in case correctRespond is called too early, before the fingerprint reader had enough time to respond. You can do something like this:
Code: [Select]
 lcd.print("Cor");
 while(Serial.available() == 0){
   delay(10);
 lcd.print("Cor=");
PaulS
Code: [Select]
    delay(10);
Can you describe the exact purpose for the delay()? Does it matter whether the while loop iterates 10 times in 100 milliseconds, or 10,000,000?
If you know (or think/hope) that the response is going to be 6 bytes, wait for 6,
Then, of course, you still need to read all 6 of them.
mr_hacker90
Code: [Select]
this command i believe just read a byte / char. if i want to put a loop, which read 6 bytes. how i'm gonna make it. of course it need a for loop. but, how i gonna integrate the counter with the serial read.
Code: [Select]
for (int n=0; n<7; n++) {
PaulS
Quote
That for loop will iterate while n = 0, 1, 2, 3, 4, 5, and 6. That's 7 iterations, not 6.
Code: [Select]
byte reply[6];
for(byte n=0; n<6; n++)
   while(Serial.available() == 0) {}; // Wait for a byte
   reply[n] = Serial.read();
// Now, reply contains all 6 bytes
PaulS
Quote
understand. now i'm using x-ctu serial terminal.
You've removed the fingerprint reader?
Quote
but the x-ctu hyperterminal shows FF
Also known as -1 (no data).
X-CTU is fine for talking to XBees. Other than that, I find it useless.
mr_hacker90
nono.. it's correct. i'm mistaken configure the baud. is shows all the 8 bytes. correctly. i just want to check whether it's write the 8 bytes. this tips is being told by my lecturer. to check the bytes of the TX pin.
mr_hacker90
the uno transmit 8 bytes. if it managed to receive respond code, how i'm gonna compare it either right or wrong? can i just make it like this? correct respond is 6 bytes while wrong respond is 7 bytes.
Code: [Select]
for(byte n=0; n<7; n++)
    respond[n] = Serial.read();
    if (respond== "0x4D + 0x58 + 0x30 + 0x01 + 0x01 + 0xD7"){
        lcd.print("Correct Respond");
    else if(respond== "0x4D + 0x58 + 0x30 + 0x02 + 0x40 + 0x35 + 0x4C"){
        // print the wrong respond
        lcd.print("Wrong Resp");
PaulS
Hello? Are you listening?
Code: [Select]
will iterate SEVEN times, not 6.
Code: [Select]
The address of an array of bytes will NEVER equal the address of a literal string.
You can have another array,
Code: [Select]
byte correct[] = {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7};
Then, you can use memcmp() to compare the arrays. But, you can't just make up stuff.
mr_hacker90
memcmp()? by the way, it is quite confusing. because the correct command respond is 6 bytes but wrong command respond is 7 bytes. that is the reason why i put 7 sir.
Code: [Select]
byte correctRespond[] = {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7};
byte wrongrespond[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x35, 0x4C);
the fingerprint reader respond correct or wrong not in same byte length.
PaulS
Quote
Perhaps you need to post a link to the fingerprint reader. It does not make sense to return two different length arrays when the finger print is valid and is not valid.
mr_hacker90
if u think that way, i also think the same. nevermind. but how i'm gonna post the link to the reader. i need to compare lots of byte array. memcmp()
PaulS
Quote
Use the 3rd icon on the bottom row. Paste the URL after clicking the icon.
mr_hacker90
Quote
i'm sorry. i don't understand sir.
