Topic: TX command code & RX respond code of module via serial com (Read 17613 times) previous topic - next topic
PaulS
Where did you get the fingerprint reader you are trying to talk to? We have to know something about it in order to help you.
mr_hacker90
#16
Jan 15, 2013, 03:07 pm Last Edit: Jan 15, 2013, 03:15 pm by mr_hacker90 Reason: 1
my fingerprint? this is my fingerprint that i bought. at first i juz thought simple RX & TX. i never thought that it quite difficult to a beginner like me. SN-FPR-SM630. thank you mr pauls.
http://www.cytron.com.my/viewProduct.php?pcode=SN-FPR-SM630&name=Fingerprint%20Reader%20Integrated%20SM630
mr_hacker90
i've studied a little bit. thank you to u sir.  finally understand it a little bit. but, too bad. i don't bring the reader to my house. i left it at my hostel. at least i know the basic function. but, i'm not sure either this is the correct way to compare it. but, i know the basic operation by the way. i just not sure about the
Code: [Select]
m = memcmp(operationSuccess, operation, sizeof(operationSuccess));
by the way, thank you so much sir. at least from zero. i got half of it on what you told me. i wish i could got all of it. but i know, i need to study more. thank you coz taught me.
Code: [Select]
byte operationSuccess[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x31, 0x48};
byte operation[7],m;
void operationSuccesful() {
  // Now, reply contains all 7 bytes
  for(byte n=0; n<7; n++)
    while(Serial.available() == 0) {}; // Wait for a byte
    operation[n] = Serial.read();
    if (m>0) {
      // set the cursor to column 0, line 1
      lcd.setCursor(0, 0);
      // print the number of seconds since reset:
      lcd.print("Operation Failed");
    else if (m<0) {
    else {
      lcd.print("Operation Success");
mr_hacker90
#18
Jan 16, 2013, 09:11 am Last Edit: Jan 16, 2013, 09:27 am by mr_hacker90 Reason: 1
hello everyone. i currently make try to make a simple project. uno with fingerprint reader. as startup i try to add fingerprint.
at first. i try run the fingerprint reader + uno with X-CTU only. i use the terminal of the X-CTU. i sent the command code of the reader. and the reader reply with correct respond code & success operation code.
as u can see in the picture, the first 8 bytes {0x4D, 0x58, 0x10, 0x03, 0x40, 0x00, 0x00, 0xF8} is the command code for add fingerprint. then the reader reply 6 bytes correct respond code, {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7}. later the reader reply 7 bytes success operation code, {0x4D, 0x58, 0x30, 0x02, 0x40, 0x31, 0x48}.
then, i try make the program. so that it follow exactly what the reader respond as i tested above. i manage to make the code. by using X-CTU. i key the respond code, the arduino program able to detect the 6 bytes of the correct respond code & 7 bytes of success operation.
however, when i try to combine them both, it doesn't being to be happen. the arduino uno transmit the command code. but, the reader doesn't respond to that code. i believe there is a problem with my code. but, i don't have any idea where's the problem. with all, regards.
Code: [Select]
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8,9,4,5,6,7);
byte addFingerPrint[] = {0x4D, 0x58, 0x10, 0x03, 0x40, 0x00, 0x00, 0xF8}; // 8 bytes
byte respondCorrect[] = {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7}; // 6 bytes
byte operationSuccess[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x31, 0x48}; // 7 bytes
byte timeOut[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x33, 0x4A}; // 7 bytes
byte processFailure[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x34, 0x4B}; // 7 bytes
byte parameterError [] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x35, 0x4C}; // 7 bytes
byte respond[6],operation[7],a,b,c,d;
 // initialize serial:
 Serial.begin(57600);
 // set up the LCD's number of columns and rows:
 lcd.begin(8, 2);
 displayLCD();
 addFinger();
 correctRespond();
 operationSuccesful();
void displayLCD(){
 // set the cursor to column 0, line 0
 // Print a message to the LCD.
 lcd.print("Fingerprint Reader");
void addFinger(){
 lcd.setCursor(0, 1);
 lcd.print("Add Fingerprint");
 // write the 8bytes array of the command code
 Serial.write(addFingerPrint, sizeof(addFingerPrint));
 //delay(2000);
void correctRespond() {
 // Now, reply contains all 6 bytes
 for(byte n=0; n<6; n++)
   respond[n] = Serial.read();
   a = memcmp(respondCorrect, respond, sizeof(respondCorrect));
   if (a>0) {
     lcd.print("Wrong   ");
     lcd.print("Respond ");
   else if (a<0) {
   else {
     lcd.print("Correct ");
 delay(2000);
   b = memcmp(operationSuccess, operation, sizeof(operationSuccess));
   if (b==0) {
     lcd.print("Operation");
     lcd.print("Success ");
   else {
     c = memcmp(processFailure, operation, sizeof(processFailure));
     if (c==0) {
       lcd.print("Process ");
       lcd.print("Failure ");
     else  {
       d = memcmp(parameterError, operation, sizeof(parameterError));
       if (d==0) {
         lcd.print("Parameter");
         lcd.print("Error   ");
       else {
         lcd.print("Time    ");
         lcd.print("Out     ");
 delay(2000);
PaulS
AWOL
And, by the magic of Moderation, back to a single topic.
mr_hacker90
i have a question here. is it possible for me to make a counter for the command code. for the add fingerprint add. by the way, it works. just the matter wrong connection for the RX & TX. not the programming.
AWOL
Quote
If you explain what you mean by that, probably, yes.
mr_hacker90
what i mean is this byte.
Code: [Select]
byte deleteFingerPrint[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x00, 0xF8}; // 8 bytes
above is for fingerprint address 0. for finger print address 1, the only bytes those are changing are last 3 bytes. 00 01 F9. and for address 2, 00 02 FA. 3rd last bytes is for high byte 2nd last byte is for low byte & last byte is for check some. is the any mathematical expression that i can use in order it can change automatically according to the address?
AWOL
Quote
Which one?
There are eight.
If you're saying "Can I save the fixed first five bytes in one array, and have another 2D array holding the variable final three bytes, indexed by a counter?" then the answer is yes.
Code: [Select]
const byte fixedPart [5] = {0x4D, 0x58, 0x10, 0x03, 0x42};
byte variableParts [SOME_NUMBER][3];
mr_hacker90
#25
Jan 16, 2013, 01:06 pm Last Edit: Jan 16, 2013, 01:08 pm by mr_hacker90 Reason: 1
yup. like that. but how i want to integrate it with a counter? address 0, 0x00 0x00 0xF8. address 1, 0x00 0x01 0xF9. address 2, 0x00 0x02 FA. and so on.
AWOL
You just use the first subscript of "variableParts".
Or maybe I don't understand what you mean by "counter".
mr_hacker90
lets say later i want to key in the fingerprint address that i wanted to add / delete. i will key in it in the serial monitor. so, how i'm gonna link it with the variable byte? if i want to add address 0, i key in 0 in the serial monitor. then, it will look for byte address 0. and so on. on the linking part between the key in of the address in the serial monitor & variable byte. for the structure to accept input from serial monitor, that one i know how to do it.
AWOL
Quote
Say you key in '1'.
So, '1' - '0' = 1. (or use "atoi" or whatever if you've captured a string)
Use that 1 as a subscript for the "variablePart" array.
mr_hacker90
Say you key in '1'.
i'm sorry sir. i don't get that.
