Topic: TX command code & RX respond code of module via serial com (Read 17628 times) previous topic - next topic
AWOL
Code: [Select]
high = high + input;
This will sum the ASCII value of whatever you enter - is that what you intended?
BTW, you can abbreviate it to
Code: [Select]
high += input;
Quote
by the input still yet ASCII although i already defined the input as byte.
Again, I don't understand what you mean by this.
mr_hacker90
i connected usb serial devices & check the input from arduino serial monitor by using X-CTU terminal. when i key in "10" the x-ctu terminal shows than the number is in ASCII.
mr_hacker90
by the way, how i'm gonna modify this program. the current program only one menu push button. but, i want to adjust it so that it can runs 2 menu push button. what i mean is, one main menu, and one sub menu.
Code: [Select]
// Author     : CYTRON TECHNOLOGIES SDN BHD
// Project             : Arduino Duemilanove
// Project description : Project_1: "Hello World" and utilize switch
#include <LiquidCrystal.h>
  The circuit:
* LCD RS pin to digital pin 8
* LCD Enable pin to digital pin 9
* LCD D4 pin to digital pin 4
* LCD D5 pin to digital pin 5
* LCD D6 pin to digital pin 6
* LCD D7 pin to digital pin 7
* LCD R/W pin to ground
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int analogPin = A0;
int adc_key_old;
int adc_key_in;
int NUM_KEYS = 5;
int key=-1;
int adc_key_val[5] ={30, 150, 360, 535, 760};
* PRIVATE FUNCTION: setup()
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Define of I/O pin as Input or Output
// The setup() method runs once, when the sketch starts
void setup ()
  // initialize serial:
  Serial.begin(57600);
  lcd.begin(16, 2);                         // set the lcd dimension
  lcd.clear();                              // LCD screen clear
  lcd.print("  CYTRON TECH.");              // display the text
  lcd.setCursor(0,1);                       // set lcd.setCursor (column,row)
  lcd.print(" Eg. LCD Shield");
  delay(1500);                              // delay for 3000ms
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Fingerprint Reader");
  lcd.setCursor(0,1);
  lcd.print("Select Address");
  adc_key_old = analogRead(analogPin);      // store the unpress key value
* PRIVATE FUNCTION: loop()
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Non-Stop looping
  adc_key_in = analogRead(analogPin);     // read ADC value
  adc_key_in = get_key(adc_key_in);
  if (adc_key_in==0)
    lcd.print("Menu 1");
  else if (adc_key_in==1)
    lcd.print("Menu 2");
  else if (adc_key_in==2)
    lcd.print("Menu 3");
  else if (adc_key_in==3)
    lcd.print("Menu 4");
  else if (adc_key_in==4)
    lcd.print("Menu 5");
* PRIVATE FUNCTION: get_key
* PARAMETERS:
* ~ integer
* RETURN:
* ~ unsigned int input
* DESCRIPTIONS:
* convert the ADC value to number between 0 to 4
int get_key(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
    return k;
    if (k >= NUM_KEYS)
        k = -1;     // No valid key pressed
    return k;
AWOL
Yes, ASCII is what I would expect them to be in.
Having them in EBCDIC would make things very difficult.
mr_hacker90
#64
Jan 17, 2013, 01:05 pm Last Edit: Jan 17, 2013, 04:06 pm by mr_hacker90 Reason: 1
it is quite difficult to make the input become byte although the input variable i had defined as byte. plus with the reader itself connected with uno via serial. seems like quite not possible unless i use another serial terminal devices. thus, i decided to use switch instead of the serial monitor. i have a LCD shield embedded together with 5 switches. the manufacturer included together simple program how to use the switch. but, it is only one menu. i want to adjust it so that it can become 2 menu. 1 main menu & 1 sub menu.
let say I want to have two menu on my LCD, when power on, it shows the main menu
1. XXX
2.YYY
3.ZZZ
so if I press SW1, then it will go to menu 1
then in menu 1, it will have another option :
1. AAA
2.BBB
3.CCC
so how can I program so that I can press the sw 1 again to go to the option AAA ? based with the arduino program code that i attached in previous post.
mr_hacker90
below code is already functioning. but, may i ask. is there any other way that i can make the code become less line. i think there is another way. but, i don't have any idea how to do it. i think the value of adc_key_in can be made into for loop so that if counter 0, it will call function deleteFinger0();
but i don't have any clue on how to do it. i would be glad if someone could give me a hint on how to do it. thank you.
Code: [Select]
  The circuit:
int analogPin = A0;
int adc_key_old;
int adc_key_in;
int NUM_KEYS = 5;
int key=-1;
int adc_key_val[5] ={30, 150, 360, 535, 760 };
byte deleteFingerPrint0[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x00, 0xFA}; // 8 bytes
byte deleteFingerPrint1[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x01, 0xFB}; // 8 bytes
byte deleteFingerPrint2[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x02, 0xFC}; // 8 bytes
byte deleteFingerPrint3[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x03, 0xFD}; // 8 bytes
byte deleteFingerPrint4[] = {0x4D, 0x58, 0x10, 0x03, 0x42, 0x00, 0x04, 0xFE}; // 8 bytes
byte respondCorrect[] = {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7}; // 6 bytes
byte operationSuccessDelete[] = {0x4D, 0x58, 0x30, 0x02, 0x42, 0x31, 0x4A}; // 7 bytes
byte parameterErrorDelete [] = {0x4D, 0x58, 0x30, 0x02, 0x42, 0x35, 0x4E}; // 7 bytes
byte respond[6],operation[7],a,f,g;
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
void setup ()
  lcd.clear();
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Non-Stop looping
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  if (adc_key_in==0)
    deleteFinger0();
    correctRespond();
    operationSuccesful();
    deleteFinger1();
    correctRespond();
    deleteFinger2();
    correctRespond();
    deleteFinger3();
    correctRespond();
    deleteFinger4();
    correctRespond();
* PARAMETERS:
* ~ integer
* RETURN:
* DESCRIPTIONS:
int k;
    return k;
    if (k >= NUM_KEYS)
    return k;
void deleteFinger0(){
  // set the cursor to column 0, line 1
  lcd.setCursor(0, 1);
  // Print a message to the LCD.
  lcd.print("Del Fingerprint1");
  // write the 8bytes array of the command code
  Serial.write(deleteFingerPrint0, sizeof(deleteFingerPrint0));
  delay(1500);
void deleteFinger1(){
  lcd.print("Del Fingerprint2");
  Serial.write(deleteFingerPrint1, sizeof(deleteFingerPrint1));
  delay(1500);
void deleteFinger2(){
  lcd.print("Del Fingerprint3");
  Serial.write(deleteFingerPrint2, sizeof(deleteFingerPrint2));
  delay(1500);
void deleteFinger3(){
  lcd.print("Del Fingerprint4");
  Serial.write(deleteFingerPrint3, sizeof(deleteFingerPrint3));
  delay(1500);
void deleteFinger4(){
  lcd.print("Del Fingerprint5");
  Serial.write(deleteFingerPrint4, sizeof(deleteFingerPrint4));
  delay(1500);
void correctRespond() {
  // Now, reply contains all 6 bytes
  for(byte x=0; x<6; x++)
    while(Serial.available() == 0) {}; // Wait for a byte
    respond[x] = Serial.read();
    a = memcmp(respondCorrect, respond, sizeof(respondCorrect));
    if (a==0) {
      lcd.clear();
      // set the cursor to column 0, line 0
      lcd.setCursor(0, 0);
      lcd.print("Correct Respond");
    else {
      lcd.clear();
      lcd.print("Wrong Respond");
  delay(1500);
void operationSuccesful () {
  // Now, reply contains all 7 bytes
  for(byte x=0; x<7; x++)
    operation[x] = Serial.read();
    f = memcmp(operationSuccessDelete, operation, sizeof(operationSuccessDelete));
    g = memcmp(parameterErrorDelete, operation, sizeof(parameterErrorDelete));
    if (f==0) {
      lcd.clear();
      lcd.print("Operation Success");
    else if (g==0) {
      lcd.clear();
      lcd.print("Parameter Error");
    else  {
      lcd.clear();
      lcd.print("Please Restart");
  delay(1500);
PaulS
Quote
Why do you have 5 nearly identical functions? One would suffice. Pass it arguments.
Perhaps you've observed that functions like digitalRead() don't have numeric suffixes.
mr_hacker90
in each deletefinger() function, it has it own command code need be transmitted via serial.write. perhaps if has other way, i could learn a new thing too.
PaulS
Quote
You could make that a 2D array, instead. Then, one argument would be an index that would define which row to use.
Or. use a switch statement to select which array to send. But, don't write 5 functions.
mr_hacker90
2D array? i think my experience in programming is just shallow. by the way, for the switch case. i understand that one. i'm gonna try it. but, perhaps i could learn how to do 2D array.
michinyon
Code: [Select]
Re: TX command code & RX respond code of module via serial com
« Reply #3 on: January 15, 2013, 11:11:51 AM »
Bigger Bigger Smaller Smaller Reset Reset Reply with quoteQuote
Code:
  while(Serial.available() == 0){
    delay(10);
Can you describe the exact purpose for the delay()? Does it matter whether the while loop iterates 10 times in 100 milliseconds, or 10,000,000?
If you know (or think/hope) that the response is going to be 6 bytes, wait for 6,
Then, of course, you still need to read all 6 of them.
He is calling it from setup().   Not from loop().   It is only going to run this function once.   So he has to wait here.
michinyon
Code: [Select]
because the correct command respond is 6 bytes but wrong command respond is 7 bytes. that is the reason why i put 7 sir.
Code:
byte correctRespond[] = {0x4D, 0x58, 0x30, 0x01, 0x01, 0xD7};
byte wrongrespond[] = {0x4D, 0x58, 0x30, 0x02, 0x40, 0x35, 0x4C);
This is misconceived.    Any response,  which is not the correct response,  is the wrong response.
