Topic: ATTiny Power (Read 8963 times) previous topic - next topic
retrolefty
I can't seem to find any concrete reference specifying the typical diode loss as a resistive loss at all.  I was under the impression it's a carrier loss and is not represented by Ohm's Law, and therefore does not have a heat byproduct (other than natural resistive losses in any real-world conductive material).  Pedantic as it may be, anyone know for sure?
Not ohms law as applied to resistance, more like a constant voltage drop so power dissipation is voltage drop X forward current = real power dissipated as waste heat wattage. So not like a resistor as voltage drop doesn't increase with increasing current flow, but still real power loss as in Watts = voltage drop X current.
Lefty
larryd
I have used the diode idea several times with success.
I added a 100uF capacitor from the cathode to 0 volts in these applications.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
dc42
I wouldn't call most of the power loss in a forward-biased diode resistive, but it certainly generates heat (or, in the case of an LED, heat + light).
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
fungus
I can't seem to find any concrete reference specifying the typical diode loss as a resistive loss at all.  I was under the impression it's a carrier loss and is not represented by Ohm's Law, and therefore does not have a heat byproduct...
It has to go somewhere (the laws of physics don't allow energy to vanish)
In the absence of electromagnetic radiation, where do you think it goes...?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
dhenry
Quote
If * Vfwd.
Always true, no exception, even in vectorized forms.
SirNickity
Not lost, just not used?  I don't know exactly.  I guess I rationalized the idea somewhat like this:  Take two halves of a transformer and separate them.  The induced current in the secondary coil will be lower than if they're more closely coupled.  Maybe even that can be described as a resistive loss, since there's resistance from the air gap between coils.
Ugh.  This is where being self-taught fails compared with having a formal education.
