Topic: Unreliable programming with new Arduinos (Read 5918 times) previous topic - next topic
unixtippse
Hi!
In an attempt to get up to date with the current state of Arduino, I ordered two Micros and two Leonardos. Unfortunately, I'm having a bit of an issue trying to upload sketches to both. About 4 in 5 uploads fail with the following error:
Code: [Select]
processing.app.SerialException: Serial port '/dev/tty.usbmodem24111' already in use. Try quitting any programs that may be using it.
at processing.app.Serial.touchPort(Serial.java:119)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:201)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:680)
My workaround right now is to repeatedly click Upload until it succeeds. Any idea what this is? Uploads to my Duemilanove (FTDI-Interface) with Optiboot work without error. This is on Mac OS 10.7. Happens with the cable directly on my laptop and on the USB hub.
Coding Badly
At the first occurrence of the error, are one or more instances of avrdude running?
stonent
#2
Jan 19, 2013, 08:35 pm Last Edit: Jan 19, 2013, 09:36 pm by stonent Reason: 1
Please don't be insulted if I am mentioning things that you already knew, but since I don't know all the details, I'll try to cover it.
1. Is one arduino the only thing plugged in besides a mouse and keyboard?
2. How sure are you that you're on the right port? If you're using more than one arduino they might assign different ports when plugged in. Iv'e even seen the serial ports change when plugging into a different USB port.
3. Did you select the correct board?
4. Are you using the latest Arduino IDE release?
5. Is the terminal window open? (Close it)
6. Did you try to reboot?
7. Can you try force quitting any apps that have nothing to do with the arduino other than the finder (or whatever Mac OSX calls the user interface)?
8. Do you use any other devices that could be using a serial interface (modem, terminal emulator, usb to serial cable) ?
michinyon
I get similar problems to this,   and it has been a problem ever since I got the Arduino.
First it says the COM port is busy.   Then it says the COM port doesn't exist.   It is an endless
run-around of plugging and unplugging the USB cable,  using the external wall-wart power, or not,
restarting the IDE incessantly,  rebooting the computer.....
A lot of the time,  it appears to be trying to upload the compiled arduino sketch to my mouse.
Sometimes it works,  sometimes it takes a few tries to get it to work,   sometimes it progresses
to hours of window-smashing frustration.
I would really like to know what is the REAL problem here,   because whatever the various error
messages are,  they are not the real problem.
Coding Badly
I get similar problems to this...
There is a question in reply #1.  You failed to answer the question.  If you don't answer questions no one will be able to help.
michinyon
Code: [Select]
C:\Users\Robert\AppData\Local\Temp\build4428593973120486394.tmp\MyBlink.cpp.hex
Binary sketch size: 1,624 bytes (of a 258,048 byte maximum)
processing.app.SerialException: Serial port 'COM4' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.<init>(Serial.java:171)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:172)
at processing.app.Sketch.upload(Sketch.java:1706)
at processing.app.Sketch.exportApplet(Sketch.java:1662)
at processing.app.Sketch.exportApplet(Sketch.java:1634)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2346)
at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port 'COM4' already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
This is the error message I am getting today.    according to windows task manager,  there is one instance of avrdude.exe running.
michinyon
Code: [Select]
C:\Users\Robert\Java\Arduino\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\Robert\Java\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Robert\AppData\Local\Temp\build5232822757627304353.tmp\MyBlink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\Robert\Java\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
And then,  sometimes,  I get crap like this.   Which works no better.
michinyon
And then,  on about the 17th reboot of the IDE,  it works.
Coding Badly
That happens if you try to upload while an upload is still in-progress.  Wait for an upload to finish or timeout before trying again.  You can use Task Manager to kill running instances of avrdude to speed the recovery process.
Coding Badly
avrdude: Recv:
I don't have an Arduino Mega 2560 so I can't help much with that problem.
Does the problem persist with nothing except a USB cable connected to the board?
Did you have this problem with the board when you first got it?
michinyon
I have had this problem intermittently ever since I got both of the Mega 2560 which I have.
I have had this problem with IDE version 22 and 23  and 1.01
I have had this problem with three different Windows 7 computers.
The sequence of restarts and unpluggings and reboots which works one time,   does not work the next time.
michinyon
And another thing:
How come, when I start the IDE,  it sometimes comes up with the last sketch I used,   and sometimes comes up with a useless new blank sketch,  which I then have to delete.
Why does it do this ?
If it is supposed to be saving the name of the last sketch I used,   in some config file or registry entry somewhere,   why doesn't this happen every time ?   It would not surprise me if this bogus behaviour is somehow linked to the COM port conflict.
michinyon
At what point in the upload process,   should it be expected that the sketch already running on the Arduino should stop ?
If the sketch already running on the Arduino is writing stuff to the computer through the serial/USB connection,   does this interfere with the process of uploading the new sketch ?
If you write a sketch which writes serial data to the computer,  like this one:
Code: [Select]
#include <Arduino.h>
#define LEDPIN (13)
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(LEDPIN, OUTPUT);
  int cyc=500 ;
  digitalWrite(LEDPIN, HIGH);   // set the LED on
  delay(cyc);              // wait for a second
  digitalWrite(LEDPIN, LOW);    // set the LED off
  Serial.println("tick");
And then I start the serial monitor, set the speed to 9600,  and I see
tick
tick
tick
and then I close the serial monitor,  and start the serial monitor again,    then I don't see any tick.
Should I expect not to see any tick,   the second ( third, fourth ) time I start the serial monitor ?
Coding Badly
Quote
Is the operating system up-to-date?  Have you tried updating the driver?
Immediately after compiling.  I believe, at the point the message "Uploading..." is displayed, the board should reset.
Quote
It can.  But not with the sketch you posted.
Quote
If you write a sketch which writes serial data to the computer,  like this one ... And then I start the serial monitor, set the speed to 9600,  and I see ... and then I close the serial monitor,  and start the serial monitor again,    then I don't see any tick.
Does the pin 13 LED continue to blink?
Have you tried a different USB cable?
