I am trying to generate a freq of 1hz till 600khz. I think toneAC can do it but what is the max freq that newtone can generate?
Also can it be used on a Arduino Nano?
Thanks
Roy
Thanks
Roy
This new tone lib is very cool
Thanks a lot !
Here below a sample of french movie picture melody.
#define o3C 262
#define o3Cd 277
#define o3D 294
#define o3Dd 311
#define o3E 330
#define o3F 349
#define o3Fd 370
#define o3G 392
#define o3Gd 415
#define o3A 440
#define o3Ad 466
#define o3B 494
#define o4C 523
#define o4Cd 554
#define o4D 587
#define o4Dd 622
#define o4E 659
#define o4F 698
#define o4Fd 740
#define o4G 784
#define o4Gd 830
#define o4A 880
#define o4Ad 932
#define o4B 988
#define ooo 0
#include <NewTone.h>
#define TONE_PIN 12
int tempo = 650;
// freq,duration, etc ..
int measures[] =
o3A,4,o3A,4,o3A,4,o3A,4,
o3A,8,o3Gd,8,o3A,8,o3B,8,o4C,2,
o3B,8,o4D,8,o4C,3,o3B,8,o3A,8,o3Gd,8,
o3A,8,o4E,8,o4C,8,o4E,8,o3A,8,o3E,8,o3Fd,8,o3Gd,8,
o3A,8,o4E,8,o4C,8,o4E,8,o3A,2,
o4D,4,o4D,4,o4D,4,o4D,4,
o4D,8,o4Cd,8,o4D,8,o4E,8,o4F,2,
o4C,4,o4C,4,o4C,4,o4C,4,
o4C,8,o3B,8,o4C,8,o4D,8,o4E,2,
o3Ad,4,o3Ad,4,o3Ad,4,o3Ad,4,
o3Ad,8,o3A,8,o3B,8,o4C,8,o4D,8,o4C,8,o3B,8,o4D,8,
o3A,8,o3E,8,o3Fd,8,o3Gd,8,o3A,8,o4E,8,o4C,8,o4E,8,
o3A,2,ooo,4
void setup() {}
for (int i = 0; i < sizeof(measures)/2; i=i+2)
if (measures[i]>0) NewTone(TONE_PIN, measures[i], tempo/measures[i+1]);
delay(tempo/measures[i+1] * 1.333);
noNewTone(TONE_PIN);
I would like to made some music to my robot, but I can't use virtualwire lib with new tone lib because timers is sames for both libraries.
I've found another servo lib than original who have same problem. This is fixed.
( it is sofware servo: Arduino Playground - Servo)
But not with virtual wire.
Virtual wire use timer1 (16 bits resolution). NewTone lib too.
some informations found about timers here:
http://letsmakerobots.com/node/28278
It is possible to unusable or change timer ?
thx
Try my toneAC2 library if you want to use timer 2. Also, the standard tone library also uses timer 2. I wrote NewTone and toneAC to use timer 1 if you were having a timer 2 conflict with something else. If timer 1 is your conflict, use the standard tone library or toneAC2.
Tim
Hi Tim,
Thanks for your work on the various tone libraries. I'm presently building a device that uses one to drive a speaker to play music. I have a question about usage of timers and outputs. I'd like to keep the possibility open to produce two channels of output (concurrently.) In other words I'd like to play the main melody on one digital output and harmony on another digital output. I also prefer to stick with one output/channel. Is there a tone library or combination of libraries that can do this?
Thanks!
Brilliant! Solves the < 31 Hz problem of the original.
My application: use with a micro-stepping motor driver that has step and direction inputs. This makes variable speed control very easy.
Does this library works together with addressable LED strips (NeoPixel library)?
Because to get the tight timing needed by the LED strips interrupts are disabled while sending the data.
So the original Tone() library doesnt work for me. Wondering if newTone Library works?
Any plans for supporting ATtiny85 (Adafruit Trinket)?
mcmahonrw:
Not sure if it would be possible do to the use of timers. But, I do know that my TimerFreeTone library is compatible with the ATtiny 85 (and just about any other platform as it doesn't use timers).
Tim
Hi!
I'm very new to Arduino and electronics. I'm building a capacitive touch morse keyer and I need to generate a 800 to 1200 Hz tone. I still don't know for sure if a sine wave is needed or a square wave is good enough to TX with a simple LPF.
Does the NewTone() make a square wave output like tone()?
I have found that NewTone(pin, freq) makes a little noise when it's ended with noNewTone(), but if I set a duration, the tone ends clean.
I would like to code something like this example, but with a fixed duration. Do you have other library that I could use?
Thanks in advance.
SineWave.ino (1.82 KB)
HoracioDos:
Hi!I'm very new to Arduino and electronics. I'm building a capacitive touch morse keyer and I need to generate a 800 to 1200 Hz tone. I still don't know for sure if a sine wave is needed or a square wave is good enough to TX with a simple LPF.
Thanks in advance.
Yes, NewTone creates a square wave. The Arduino can't output a sine wave. If you need a sine wave, I would suggest using a Teensy 3.2
If you end a tone early it may stop in the middle of the high state. If it ends on it's own, it always finishes the high state before ending.
I don't understand your last question. You want to code something like what example? NewTone does do a fixed duration so I'm confused.
Tim
Hello Tim!
Thanks for your quick answer.
I have attached in the previous post an example from make magazine that creates a sine wave that never ends. I'm trying to merge your library and this example to generate a sine wave with a fixed duration. As I dont want to abuse of your time ¿Do you know or have something already made that I can use?
For example teensy 3.2 could be an option.
Again Thanks!
H
HoracioDos:
Hello Tim!Thanks for your quick answer.
Again Thanks!
H
Just so you know, this doesn't generate a sine wave. It creates a simulated sine wave. You could create a sketch that would modify this SineWave sketch and create a function that would play a simulated sine wave at a preset frequency. But, it will still be a simulated sine wave, not an actual sine wave.
Keep in mind that a digital pin can only be on or off. So, no matter the code, that's all it can output. This SineWave sketch doesn't actually produce anything close to an actual sine wave. In other words, if you really need a sine wave, this SineWave sketch isn't going to do it for you.
Tim
Thank you Tim for explaining me so clearly. You have helped a lot and made think about other options.
Certainly not the author's fault, but FYI I attempted to use this as a drop-in replacement for tone in my application and caused a small fire... (I'm driving an inductor/oscillator pretty hard). Not sure if the duty cycle was higher, or it just kept the pin high for too long for some other reason.
The only other library i'm using in this sketch is debounce, I don't think there are any timer conflicts there
outlookhazy:
A timer conflict wouldn't cause it and even if the pin was kept high for a long time it wouldn't cause a fire at 5 volts. Something else is wrong, it's not the software.
Tim
You may be intersted in a problem I have encountered when using TimerFreeTone on a DUE;
http://forum.arduino.cc/index.php?topic=442298.msg3044752#msg3044752
I dont think the problem is with TimerFreeTone, but something unique to the DUE, whereby the timing (TimerFreeTone or bitbanging) gets messed up depending on where the code ends up in memory.
srnet:
You may be intersted in a problem I have encountered when using TimerFreeTone on a DUE;Odd Problems with Audio Tone Generation on DUE - Arduino Due - Arduino Forum
All TimerFreeTone is does is set a pin high, delay, set pin low, delay, repeat until duration is met. This would also be the same with the code you wrote on your own. Therefore, there must be something happening with the delayMicroseconds() function on the Due.
While TimerFreeTone doesn't use a timer interrupt, other code could be which could cause problems with the delayMicroseconds() function. For example, Serial.write() uses interrupts which could throw off the delayMicroseconds() function, which in turn would mess up TimerFreeTone.
I believe you've answered your own question. Serial.write() effects the timer functions on the DUE for a few ms as it writes data to the serial port. So, if you must use a Serial.write(), add a delay after so it doesn't mess with the frequency you're trying to generate with TimerFreeTone.
The other solution is to use one of the timers on the DUE to replace TimerFreeTone. While TimerFreeTone will work on the DUE, there's far better and more accurate ways of doing it on the DUE.
Tim
PLAYBACK of RAW wave data
Im playing around with your Newtone lib, and I want to playback a raw sound file (1 second) loaded in the flash mem of the nano.
My problem is in what format do I have to provide the sound data that it plays correctly
(The origin is a wav file which I converted to raw 8 bit data with the correct sample rate 2 kHz).
In your comments of the toneAC thread I read, that it is easy to playback raw sound data.
I would be glad if you or some else could give me a hint how to do it.
(I can not use a media player because I want to modify the frequency during runtime)
2knuckels:
PLAYBACK of RAW wave dataIm playing around with your Newtone lib, and I want to playback a raw sound file (1 second) loaded in the flash mem of the nano.
The sample NewTone library sketch (https://bitbucket.org/teckel12/arduino-new-tone/wiki/Home#!example) plays back a song. You would use a similar process to convert your raw sample to frequencies and build an array would you would then loop through.
Tim
Thank you for the quick reply.
So I am on the right way, ->
I only have to find the right delays, because the main frequencies I got with an FFT.
(15 Hz, 38 Hz, 79 Hz peak 2, 92 Hz peak 1, 115 Hz, 184 Hz, 267 Hz peak 3)
In case someone has already found the "melody" for the lightsaber "hum" it would be kind to post it.
