ard_newbie:
I tried to upload this Library this way, and I think it works (at least, I have no error at compile time):Open a new sketch that you can call Complex.ino :
// FILE: complex.ino
// AUTHOR: Rob Tillaart
// DATE: 2013-09-23
// PUPROSE: test complex math
// Serial.print(Complex) supported since 0.1.05
#include "complex.h"
Serial.print("\n Complex numbers test for Arduino: ");
Serial.println(COMPLEX_LIB_VERSION);
Serial.println("\n1. Print Complex, set, real, imag");
Complex c1(10.0, -2.0);
Complex c2(3, 0);
Complex c3(-10, 4);
Complex c4(-5,-5);
Complex c5(0, 0);
Serial.println(one);
Serial.println(c1);
Serial.println(c2);
Serial.println(c3);
Serial.println(c4);
c3.set(0,0);
Serial.println(c3);
Serial.println(c3.real());
Serial.println(c3.imag());
Serial.println("\n2. == != ");
c5 = c1;
if (c5 == c1) Serial.println("ok :)");
else Serial.println(" fail :(");
c5 = c1 + 1;
if (c5 != c1) Serial.println("ok :)");
c5 = 3;
if (c5 == 3) Serial.println("ok :)");
Serial.println("\n3. negation - ");
c5 = -c1;
Serial.println(c5);
c5 = -c5;
Serial.println(c5);
Serial.println("\n4. + - ");
c5 = c1 + c2;
Serial.println(c5);
c5 = c1 + 3;
Serial.println(c5);
c5 = c1 - c2;
Serial.println(c5);
c5 = c1 - 3;
Serial.println(c5);
Serial.println("\n5. * / ");
c5 = c1 * c2;
Serial.println(c5);
c5 = c5 * 3;
Serial.println(c5);
c5 = c5 / c2;
Serial.println(c5);
c5 = c5 / 3;
Serial.println(c5);
c5 = c1 / c2 * c2;
Serial.println(c5);
c5 = c1 * c4 / c4;
Serial.println(c5);
Serial.println("\n6. assign += -= *= /=");
c5 = c1;
c5 += c1;
Serial.println(c5);
c5 += 3;
Serial.println(c5);
c5 -= c1;
Serial.println(c5);
c5 -= 3;
Serial.println(c5);
c5 *= c1;
Serial.println(c5);
c5 *= 3;
Serial.println(c5);
c5 /= c1;
Serial.println(c5);
c5 /= 3;
Serial.println(c5);
Serial.println("\n7. phase modulus polar");
Serial.println(c1);
double m = c1.modulus();
Serial.println(m);
double p = c1.phase();
Serial.println(p);
c5.polar(m, p);
Serial.println(c5);
Serial.println("\n8. conjugate reciprocal");
c5 = c1.conjugate();
Serial.println(c5);
c5 = c5.conjugate();
Serial.println(c5);
c5 = c1.reciprocal();
Serial.println(c5);
c5 = c5.reciprocal();
Serial.println(c5);
Serial.println("\n9. power: exp log pow sqrt sqr logn log10");
c5 = c1.c_sqr();
Serial.println(c5);
c5 = c1.c_exp();
Serial.println(c5);
c5 = c5.c_log();
Serial.println(c5);
c5 = c1.c_pow(2);
Serial.println(c5);
c5 = c5.c_sqrt();
Serial.println(c5);
c5 = c5.c_sqr();
Serial.println(c5);
c5 = c1.c_pow(c2);
Serial.println(c5);
c5 = c5.c_pow(c2.reciprocal());
Serial.println(c5);
c5 = c5.c_logn(c4);
Serial.println(c5);
c5 = c4.c_pow(c5);
Serial.println(c5);
c5 = c5.c_log10();
Serial.println(c5);
Serial.println("\n10. gonio: sin cos tan asin acos atan");
c1.set(0.5, 0.5);
c5 = c1.c_sin();
Serial.println(c5);
c5 = c5.c_asin();
Serial.println(c5);
c5 = c1.c_cos();
Serial.println(c5);
c5 = c5.c_acos();
Serial.println(c5);
c5 = c1.c_tan();
Serial.println(c5);
c5 = c5.c_atan();
Serial.println(c5);
Serial.println("\n11. gonio csc sec cot acsc asec acot");
c1.set(0.5, 0.5);
c5 = c1.c_csc();
Serial.println(c5);
c5 = c5.c_acsc();
Serial.println(c5);
c5 = c1.c_sec();
Serial.println(c5);
c5 = c5.c_asec();
Serial.println(c5);
c5 = c1.c_cot();
Serial.println(c5);
c5 = c5.c_acot();
Serial.println(c5);
Serial.println("\n12. gonio hyperbolicus I ");
c1.set(0.5, 0.5);
c5 = c1.c_sinh();
Serial.println(c5);
c5 = c5.c_asinh();
Serial.println(c5);
c5 = c1.c_cosh();
Serial.println(c5);
c5 = c5.c_acosh();
Serial.println(c5);
c5 = c1.c_tanh();
Serial.println(c5);
c5 = c5.c_atanh();
Serial.println(c5);
Serial.println("\n13. gonio hyperbolicus II ");
c1.set(0.5, 0.5);
c5 = c1.c_csch();
Serial.println(c5);
c5 = c5.c_acsch();
Serial.println(c5);
c5 = c1.c_sech();
Serial.println(c5);
c5 = c5.c_asech();
Serial.println(c5);
c5 = c1.c_coth();
Serial.println(c5);
c5 = c5.c_acoth();
Serial.println(c5);
Serial.println("\n.. Complex done");
uint32_t start = micros();
for (int i=0; i<1000; i++)
c5 = c5.c_csc();
uint32_t dur = micros() - start;
Serial.println(dur);
// END OF FILE
/* OUTPUT:
Complex numbers test for Arduino: 0.1.09
1.000 0.000i
10.000 -2.000i
3.000 0.000i
-10.000 4.000i
-5.000 -5.000i
0.000 0.000i
0.00
0.00 -
ok
ok
ok -
negation -
-10.000 2.000i
10.000 -2.000i
ok -
13.000 -2.000i
13.000 -2.000i
7.000 -2.000i
7.000 -2.000i
30.000 -6.000i
90.000 -18.000i
30.000 -6.000i
10.000 -2.000i
10.000 -2.000i
10.000 -2.000i
assign += -= *= /=
20.000 -4.000i
23.000 -4.000i
13.000 -2.000i
10.000 -2.000i
96.000 -40.000i
288.000 -120.000i
30.000 -6.000i
10.000 -2.000i -
phase modulus polar
10.000 -2.000i
10.20
-0.20
10.000 -2.000i -
10.000 2.000i
10.000 -2.000i
0.096 0.019i
10.000 -2.000i -
96.000 -40.000i
-9166.244 -20028.609i
10.000 -2.000i
96.000 -40.000i
10.000 -2.000i
96.000 -40.000i
880.000 -592.000i
10.000 -2.000i
0.534 0.542i
10.000 -2.000i
1.009 -0.086i -
0.541 0.457i
0.500 0.500i
0.990 -0.250i
0.500 0.500i
0.404 0.564i
0.500 0.500i -
1.078 -0.912i
0.500 0.500i
0.950 0.240i
0.500 0.500i
0.839 -1.172i
0.500 0.500i -
0.457 0.541i
0.500 0.500i
0.990 0.250i
0.500 0.500i
0.564 0.404i
0.500 0.500i -
0.912 -1.078i
0.500 0.500i
0.950 -0.240i
0.500 0.500i
1.172 -0.839i
0.500 0.500i
.. Complex done
116805
1.000 0.000i
and Inside the IDE window, click in the upper right Arrow to open a folder Inside this window that you call Complex.h . Copy and paste Complex.h from the original library inside Complex.h. Click again in the upper right Arrow and add a new folder Inside Complex.ino that you call Complex.cpp . Copy and paste Complex.cpp from the original Library Inside Complex.cpp Then compile, upload and run Complex.ino on your DUE. I did a copy of the results at the end of Complex.ino above.
In the following link you will find the complex library that works on Arduino DUE, just read the ReleaseNote.txt. Your post @ard_newbie was very helpful to find this compilation mistake.
