Topic: [Solved] 74HC595 problems (Read 2818 times) previous topic - next topic
Steen
Jan 24, 2013, 02:04 am Last Edit: Jan 29, 2013, 03:42 pm by Steen Reason: 1
Hi
I was trying to get my LED matrix working again today, and stumbled upon a problem. I have two 74HC595 cascaded. The first one (to which I send the data) is the colum driver, the 2nd one is the row driver.
Usually when you run this code:
Code: [Select]
int latchPin = 8; //9->8
int dataPin = 11; //8->11
int clockPin = 12; //10->12
byte col = 0b10000000;
byte row = 0b10000000;
 pinMode(latchPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 pinMode(dataPin, OUTPUT);
 digitalWrite(latchPin, LOW);
 shiftOut(dataPin, clockPin, LSBFIRST, row);
 shiftOut(dataPin, clockPin, MSBFIRST, col);
 digitalWrite(latchPin, HIGH);
The LED is constantly lit, right?
Since when you sent the data and pulled latchPin up, the register remembers its bits and keeps outputting them constantly, right?
Well, I don't see it. It keeps flickering every second.
It never lights up constantly, I really have no clue what I am doing wrong, I have checked the schematics over 10 times, and can't see any mistake.
Note the everything works actually, I can address every row and colum as I should be able to, but somehow the outputs of the shift registers don't have continuous outputs... Is it possible that I broke something?
Nick
John_Smith
#1
Jan 24, 2013, 04:12 am Last Edit: Jan 24, 2013, 04:26 am by Boffin1 Reason: 1
How are you driving the LEDs  the 595s ?
45 years of editing projects with a knife and soldering iron, then I found Arduino !
CrossRoads
Show your schematic.
Probably needs a 0.1uF cap on the Vcc pin of each part - and nowhere else.
John_Smith
Hi Crossroads,
Quote
and nowhere else.
Can we not get that example with the cap on the latch line corrected ?
http://arduino.cc/en/Tutorial/ShiftOut
CrossRoads
When pigs fly apparently...
John_Smith
Steen
It's solved, There seemed to be a faulty cable, I just reconnected it and it works now :)
The cable was one connected to GND, so that might be a reasonable explanation.
Hippynerd
Hi Crossroads,
Quote
and nowhere else.
Pretty please? sigh could we also put some decoupling caps on the TLC5940 Tutorial too? how about a simple explanation of why you need them, what is the proper size, and how you determine the size.
Is that really too much to ask for? I suppose it probably is.
https://sites.google.com/site/rgbledcubes
dhenry
Quote
How dare you? Providing an example where the fault is not decoupling caps?
