Topic: Arduino Leonardo fryed? (Read 1 time) previous topic - next topic
Ales
i just made a stupid mistake and have connected 12 volts (reversed polarity) to 5v+  :smiley-eek-blue:
Yes... i really did this, not intentionaly though :D
Now, when i connect my leonardo to usb ALL leds power on on the arduino board, and in PC there is no COM port (ardino)
Is this meaning i have just fried my leonardo or can i replace some voltage regulator or diode maybe?
How can i check this?
Thanks for help :D
larryd
You will have to get a new board, more cost efficient than fixing the old one.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Ales
I think this is the voltage regulator
http://si.farnell.com/texas-instruments/reg1117-5/v-reg-ldo-5-0v-1117-sot-223-3/dp/1212858
So the price for 1 regullator is 2,95 + shipping 5 => 7,98 eur
new bord is 3x that price....
BUT
How can i be 100% that only the regulator is bad?
larryd
Quote
If you connected +12 volts to +5 volts you have blown the chips and possibly the electrolytic capacitors.
If you connected +12 to GND and 0 Volts of the 12 Volts to +5V everything is gone.
Quote
Buy one, replace it, if it works 100% then only the regulator was bad.
No technical PMs.
Ales
LarryD thanx....
I have just ordered new bord :D
larryd
1. If you have an external 5 volt (short circuit proof) supply.
2. Remove the regulator.
3. Place wires into GND and +5Volts.
4. Connect these wires (observe polarity) to your external 5 volt supply.
No technical PMs.
