Topic: Timebomb-Styled Clock Issue (Read 773 times) previous topic - next topic
Dawmasta
Hello!
I'm trying to program a 4-digit 7-segment display and piezo (with more components later) to count down until a climactic... something. I've got the 7-segment display working nicely, but when I add in the piezo, things get iffy. It should buzz for 50ms and be off for 950ms, but the display also follows these delays, making it impossible to read. If anyone can correct my code, I'd be very grateful!
Code: [Select]
int digit1 = 11; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 9; //PWM Display pin 6
int digit4 = 6; //PWM Display pin 8
int segA = A1; //Display pin 14
int segB = 3; //Display pin 16
int segC = 4; //Display pin 13
int segD = 5; //Display pin 3
int segE = A0; //Display pin 5
int segF = 7; //Display pin 11
int segG = 8; //Display pin 15
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
  pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  pinMode(digit4, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(13, OUTPUT);
//---------------------------------------------------------------------TROUBLE SPOT-----------------//
  digitalWrite(2, HIGH);
  delay(50);
  digitalWrite(2, LOW);
  delay(950);
  displayNumber(59-millis()/1000);
  while( millis() > 60000) {
    displayNumber(0);}
//---------------------------------------------------------------------/TROUBLE SPOT----------------//
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS  500
#define DIGIT_ON  HIGH
#define DIGIT_OFF  LOW
  long beginTime = millis();
  for(int digit = 4 ; digit > 0 ; digit--) {
    switch(digit) {
    case 1:
      digitalWrite(digit1, DIGIT_ON);
    case 2:
      digitalWrite(digit2, DIGIT_ON);
    case 3:
      digitalWrite(digit3, DIGIT_ON);
    case 4:
      digitalWrite(digit4, DIGIT_ON);
    lightNumber(toDisplay % 10);
    toDisplay /= 10;
    delayMicroseconds(DISPLAY_BRIGHTNESS);
    lightNumber(10);
    digitalWrite(digit1, DIGIT_OFF);
    digitalWrite(digit2, DIGIT_OFF);
    digitalWrite(digit3, DIGIT_OFF);
    digitalWrite(digit4, DIGIT_OFF);
  while( (millis() - beginTime) < 10) ;
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON  LOW
#define SEGMENT_OFF HIGH
  switch (numberToDisplay){
  case 0:
    digitalWrite(segA, SEGMENT_ON);
    digitalWrite(segB, SEGMENT_ON);
    digitalWrite(segC, SEGMENT_ON);
    digitalWrite(segD, SEGMENT_ON);
    digitalWrite(segE, SEGMENT_ON);
    digitalWrite(segF, SEGMENT_ON);
    digitalWrite(segG, SEGMENT_OFF);
  case 1:
    digitalWrite(segA, SEGMENT_OFF);
    digitalWrite(segD, SEGMENT_OFF);
    digitalWrite(segE, SEGMENT_OFF);
    digitalWrite(segF, SEGMENT_OFF);
  case 2:
    digitalWrite(segC, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_ON);
  case 3:
  case 4:
  case 5:
    digitalWrite(segB, SEGMENT_OFF);
  case 6:
  case 7:
  case 8:
  case 9:
  case 10:
guix
Hello,
Look the Blink without delay example to understand how to replace the delay function and the while loops with similar but non blocking code.
