Topic: "Security" System = Arduino+PIR+LCD+DS1307 (Read 6714 times) previous topic - next topic
gtr_stitch
Hello again...
I've been working on a project that has interested me ever since I got my hands on the Uno - my "home "security" system" (I put security in quotes mainly because, well, it's not really security, more so monitoring/indication). Anyways, I finished the project some time ago, and just a while ago, added the DS1307 RTC to it (just to add a little functionality/style, if you will). So, here is me showing it off a little bit :) it's by no means perfect, and as usual, I welcome feedback and criticism. By no means does this project really secure anything. I would not recommend setting this up as a serious home security measure (unless you have the resources, in that case, more power to you!)
Here is the sketch;
Code: [Select]
/* BLUE/STR.BLUE - REED SW.
  PIR - Vs: STR.ORANGE, GND:BRN, OUT: STR.GRN
  Author - Gtr_Stitch
  01/27/2013
#include <LiquidCrystal.h>
int piez = 8;
volatile int state = LOW;
LiquidCrystal lcd(4,5,6,7,9,10);
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup(){
  RTC.begin();
  Wire.begin();
  lcd.begin(16,2);
  attachInterrupt(0,sound,RISING);
  attachInterrupt(1,sound2,RISING);
  pinMode(3,INPUT);
  pinMode(11, OUTPUT);
  lcd.setCursor(0,0);
  lcd.print("--INITIALIZING--");
  lcd.setCursor(0,1);
  lcd.print(" PLEASE WAIT...  ");
  delay(30000); // give the PIR time to calibrate
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("    *ACTIVE*    ");
  delay(2000);
void indicator(){
  digitalWrite(11, HIGH);
  delay(250);
  digitalWrite(11, LOW);
  delay(250);
void trip_door(){
   lcd.setCursor(0,0);
   lcd.print("  BREACH  DOOR  ");
   indicator();
void trip_motion(){
    lcd.setCursor(0,1);
    lcd.print("     MOTION     ");
    indicator();
void loop(){
  int door = digitalRead(2);
  int pir = digitalRead(3);
  if ( door == LOW){
    trip_door();
  else if ( pir == HIGH){
    trip_motion();
  else {
  DateTime now = RTC.now();
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print(now.hour(), DEC);
  lcd.print(':');
  lcd.print(now.minute(), DEC);
  lcd.print(':');
  lcd.print(now.second(), DEC);
void sound()
  tone(8, 500, 500);
void sound2()
  tone(8, 750, 500);
In a nutshell, the Uno monitors the PIR and a magnetic reed switch attached to the door downstairs. If either is tripped, a buzzer and a flashing led indicates motion or the door is open. When all is quiet, I query the time from the RTC, and a simple clock keeps the time. Pic down below. I used a very long cat5 cable to reach from downstairs to my computer desk. Because of the cat5's length, I've had some issues with interference, which I'm working on.
In another project, I fashioned a combination lock out of five push buttons and a servo. Maybe later on I'll incorporate that into this project. But that's another story :)
'Til next time!
~Stitch
cyclegadget
Sorry that you did not get any responses. So many posts, so little time. You are on the right track. You have got a project to work that is practical and useful! You have also did a good job sharing your code and you provide a picture. I applaud your work and appreciate that you shared it!
Don't worry to much about responses, they do not always represent the majority of people's opinions.
codlink
I agree, with cycle, I come on this forum a few times a day and this is the first time I have seen this post.
Anyway, congrats on the working system!  You should post up a little tutorial on instructables or somewhere.  Lots of people have trouble getting a "security" system working.
//LiNK
OptoLcd
Thanks for this.
I have all the parts and hope to try your code out when I finish my current project.
Cheers,
Austin
JimboZA
I would probably add an electrified net like Wolowitz rigged up for Sheldon's and Leonard's apartment....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
RudiAhlers
Would you mind telling me which PIR you're using?
dex1337
Hello sir,
               Ive been working on a similar project to attach 4 PIR sensors to my 16,2 LCD.
Can you please b kind enough to guide me with required modifications to your source code? I'm a total beginner in embedded electronics.
Thanking you
b-james
How come pictures don't automatically appear any more?
CrossRoads
#9
Nov 07, 2015, 11:46 pm Last Edit: Nov 07, 2015, 11:50 pm by CrossRoads
dex1337, you're asking on a 2+ year old topic, don't be surprised if there is no response.
b-james, Attached pictures used to open, now you have to click them. I don't know why that was changed.
One can also use the image and link tags to embed a link and display a picture hosted elsewhere:
http://www.crossroadsfencing.com/BobuinoRev17/
