Topic: ABC - Arduino Basic Connections (Read 437706 times) previous topic - next topic
PaoloP
... è un po' come prendere 29 ad un esame universitario  :D
Io ne presi uno...  :smiley-sweat: :smiley-sweat:
zoomx
E' vero, fermarsi per settimane al 99% non è proprio il massimo. Potrebbe anche significare che non sai farti i conti.
pighixxx
Aggiornato il primo post con l'elenco di tutte le basic connect che pubblicherò a giorni. Per chi non ha voglia di tornare al primo post  :smiley-mr-green: le riporto qui:
  • Light a LED
  • One LED to GND
  • One LED to Positive
  • Dual LEDs
  • Bicolor LED
  • Cluster
  • Luxeon
  • Multiple Cluster or LED Strip
  • Decoder/Multiplexer 74HC238
  • 74HC238 simple schematic
  • RGB Common Cathode
  • RGG Common Anode
  • LED Strip
  • CD4017
  • CD4017 simple schematic
  • Charlieplexing
  • Advanced Charlieplexing
  • LED Array
  • 74HC595
  • 74HC595 simple schematic
  • Connect multiple 74HC595
  • MAX7219
  • Controlling LED matrix displays with the MAX7219
  • Connect multiple MAX7219
  • TLC5940
  • TLC5940 simple schematic
  • Connect multiple TLC5940
  • Pushbutton to GND
  • Pushbutton to 5V
  • Using internal pullup
  • Pushbutton to 12V
  • Simple debouncer
  • Debouncing a pushbutton
  • Multiple buttons using 1 analog input
  • Emulating button presses
  • Optocoupled input
  • Optocoupled input (AC Input)
  • A simple water level sensor
  • Connect a PS2 device
  • Debouncing a Rotary encoder
  • Connect an encoder
  • Connect an encoder (Internal pullup)
  • Pushbutton to 3V3 tolerant pins
  • Connect a keypad
  • Connect a keypad (with interrupt)
  • Connect a keypad (using 1 analog input)
  • Keypad
  • Keyboard scan codes
  • Connect a Thumbwheel switch
  • Thumbwheel switch codes
  • Connect a DS touchscreen
  • A water level sensor
  • PS2 pinout
  • Connect a diverter
  • Connect a diverter (using 1 analog input)
  • Multiplexing 8 potentiometers
  • Connect a rotary switch
  • Connect a rotary switch (with 1 analog input)
  • Connect 8 digital inputs via SPI
  • 74HC165
  • Connect multiple 74HC165
  • Connect a digital potentiometer
  • Use a photoresistor as ON/OFF signal
  • Connect a relay
  • Connect a relay (optoisolated)
  • Connect a lamp (DC Low voltage)
  • Connect a Mosfet
  • Connect a DC Motor
  • Connect a solenoid
  • Connect a computer fan (3 wires)
  • Connect a computer fan (4 wires)
  • Connect a CT Sensor
  • Current sensor
  • Measuring DC current
  • Voltage Measurement
  • Connect a RTD Temperature Sensor
  • Connect a LM35 Temperature Sensor
  • Connect a LM35 Temperature Sensor (Full range scale application)
  • Connect a TMP36 Temperature Sensor
  • Connect a DS18B20 Digital Temperature Sensor
  • Connect a DHT11 Temperature & Humidity Sensor
  • Connect a Thermocouple
  • A Sound Sensor
  • A Vibration Sensor
  • Connect a Gas Sensor
  • Connect a Buzzer
  • Connect a Buzzer (with transistor)
  • A 1 transistor Audio Amplifier
  • Audio Amplifier
  • Connect an Audio Amplifier
  • Connect a Microphone
  • Zero crossing detect
  • Connect a Triac
  • Connect a Servo
  • Drive a Unipolar Stepper - 1
  • Drive a Unipolar Stepper - 2
  • Drive a Bipolar Stepper - 1
  • Drive a Bipolar Stepper - 2
  • Drive motors with ULN2803
  • Drive a Motor with L298
  • Bi-Directional Voltage Level Converter 3.3V to 5V
  • Bi-Directional Voltage Level Converter 3.3V to 5V with voltage divider
  • TTL/CMOS Converter
  • TTL/CMOS Converter (6 inputs/outputs)
  • 7 segments display
  • 7 segments display (with multiplexing)
  • 7 segments display (with MAX7221)
  • Connect a LCD Hitachi 44780 Compatible
  • Connect a LCD Hitachi 44780 Compatible via I2c
  • Connect a NOKIA Lcd
  • Connect a Graphical LCD via I2c
  • Connect a IR Sensor
  • Connect a IR Emitter
  • Connect an EEPROM?Connect to VGA
  • Connect to Composite Video
  • Connect a PS2 Controller
  • MAX232
  • Simple Serial Interface
  • MIDI Interface
  • DMX Interface
  • RS485
  • Port Expander with PCF8574
  • Port Expander with MCP23017
  • Shift Register
  • Connect a DAC
  • Connect a SHARP Distance Sensor
  • Connect a SD Card
  • Connect a RTC
  • Connect 2 MPU
  • Protect a I/O Pin
  • DIY
  • A Logic Analyzer
  • Simple 5V Power Supply
  • Simple 3V3 Power Supply
  • ?Resistors
  • Capacitors
  • Transistors
astrobeed
Come segnalato in questo topic c'è un errore sullo stato logico per la condizione ON nella seconda scheda, quella dei led, relativo al cluster e alla lampadina.
Ulteriore nota tecnica, sulla lampadina ad incandescenza non serve il diodo in antiparallelo in quanto è un carico resistivo.
Scientia potentia est
pighixxx
Ciao Astro,
i disegni li ho rifatti tutti da zero ed eventuali errori (segnalati e non) sono stati corretti (almeno spero  :D)
Inoltre buona parte delle soluzioni sono state riadattate. Grazie,
Alberto
astrobeed
Il pdf che ho scaricato poco fa, quello al link del primo post, porta come data di ultima modifica il 10/4/2104.
pighixxx
Si, penso sia la raccolta di pdf che aveva fatto Guglielmo da quando il sito non è raggiungibile.
I nuovi disegni li ho iniziati un mese fa e non li ho mai pubblicati. Se aspetti un attimo pubblico una preview
pighixxx
Ecco una piccola preview.
Alla fine le schede saranno poco più di 120 e saranno divise in maniera logica (Input, Output, ecc)
Le righe rosse sono guide che mi sono dimenticato di disattivare  :D
pighixxx
(si può fare l'attach di solo 4 file)
testato
manca un 2 nella sequela di 2 usati per il transistor led cluster  ;)
- [Guida] IDE - http://goo.gl/ln6glr
- [Lib] ST7032i LCD I2C - http://goo.gl/GNojT6
- [Lib] PCF8574+HD44780 LCD I2C - http://goo.gl/r7CstH
pighixxx
testato
sempre primo schema, i led si accendono con pin HIGH  ;)
pighixxx
Si
quello è già stato corretto. Sto ripassando tutte le schede per poi pubblicarle. Il 2 peró mi era proprio sfuggito (Anche perchè sto incominciando a vederci doppio)  :smiley-mr-green:
testato
azz, due errori nella prima scheda, ho paura di aprire la seconda
p.s.: mi aspetto che la risposta sia: "Bastardo !"  :smiley-mr-green:
nid69ita
@Pighi, questo ti è sfuggito ?  Lo segnala @astro.
http://forum.arduino.cc/index.php?topic=261454.msg1845492#msg1845492
my name is IGOR, not AIGOR
