Arduino Forum
Using Arduino
Programming Questions
Problem using Google Docs server?
Print
Pages:
[1]
Topic: Problem using Google Docs server?
(Read 1 time)
previous topic
next topic
dropkinn
Guest
Feb 02, 2013, 04:51 am
First off here's the code:
http://pastebin.com/2wLFLqvR
i'm taking code from a couple different places:
Mainly:
http://www.open-electronics.org/how-send-data-from-arduino-to-google-docs-spreadsheet/
Here's the form i need to enter data into:
https://docs.google.com/spreadsheet/viewform?formkey=dEMyVVE3dGNzbF8yVXNiNXh3R21JMnc6MQ
The arduino is never able to connect to the server, is there any alternative? I honestly dont know what ip i need, google docs? google? Any help would be greatly appreciated, Noah.
MikMo
Guest
Re: Problem using Google Docs server?
#1
Feb 02, 2013, 08:10 am
Are you sure your arduinos ethernet shield and the associated protocol stack can make HTTPS connections ?
As far a i know that i not possible.
Mikael
dropkinn
Guest
#2
Feb 02, 2013, 03:16 pm
The code i found used https but that does make a lot of sense. Any workaround? Drop the s?
Thanks, Noah.
PaulS
Guest
#3
Feb 02, 2013, 03:58 pm
Quote
Drop the s?
If you don't mind failure, that's a good idea.
You need to host your data on a server that lets you use http to access it, not one that requires https.
dropkinn
Guest
#4
Feb 02, 2013, 04:30 pm
Every example script I've seen and everyone else using gdocs with arduino haven't reported any problems using https.
MikMo
Guest
#5
Feb 02, 2013, 05:16 pm
Do they use the same ethernet shield as yours?
PaulS
Guest
#6
Feb 02, 2013, 05:22 pm
Are you able to connect to ANY server? You need to narrow down the problem.
Print
Pages:
[1]
Loading...
