Topic: amplifying mic signals in an arduino (Read 3581 times) previous topic - next topic
harshvardhan
i researched google quite a bit to get something to amplify the signals of a mic.
i have been thinking, what is the problem of using an op amp?
wont that work?
CrossRoads
Op amp would be fine.
Use one that will work with a 0/5V supply, bring your mic in thru a capacitor to an input pin; use 2 10K resistors to have the pin sit at 2.5V.
http://www.electronics-tutorials.ws/opamp/opamp_3.html
harshvardhan
please show me the breadboard view of the schematic with the ca3140 .
also, wont a simple transistor work?
Grumpy_Mike
Don't get greedy, it is such a simple circuit it will do you good to lay it out yourself.
No you can't get that much gain out of a single transistor.
andygrove
You might consider buying an op-amp breakout board like this one for $5:
https://www.sparkfun.com/products/9816?
Or even better here is a breakout board with a Mic and a built-in amplifier for $8:
https://www.sparkfun.com/products/9964
I used the latter successfully in an Arduino project that took Mic input, applied a ring modulator effect, and then played the output on a speaker. Here is a link with circuit diagrams and code:
https://github.com/andygrove/arduino_dalek_ringmodulator
Hope that helps.
