Topic: WS2811 in DIP package, where to buy? (Read 5442 times) previous topic - next topic
fungus
Feb 07, 2013, 01:30 pm Last Edit: Feb 07, 2013, 01:32 pm by fungus Reason: 1
The WS2811 datasheet mentions it's available in an 8-pin DIP package.
Does anybody know where you can buy them in small quantities?
(I'm guessing they'll be horribly expensive if you can get them but you never know...)
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
johnwasser
The manufacturer (http://www.world-semi.com/) seems to be offline.
I can't find ANY source for the DIP-8 version in ANY quantity.  If you want to use that chip you may need to learn surface-mount soldering so you can use the SOP-8 package.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
fungus
Maybe...but then I'd need suitable PCBs, etc., as well.
It's just an idea I had for running half a dozen 12mm RGB LEDs while keeping cabling to a minimum.
I guess I'll have to figure out another way to do it. Maybe there's a WS2811/WS2801 breakout board out there for a reasonable price.
CrossRoads
The only place I have seen WorldSemi parts offered is e-bay from a company in Niagara Falls.
I would try that.
Search for WS2803 which I know they sell and work back to their store from there.
CrossRoads
John,
Ready for a little snow?
Could put a damper on Friday night traffic 8)
fungus
#5
Feb 07, 2013, 05:03 pm Last Edit: Feb 07, 2013, 06:08 pm by fungus Reason: 1
I would try that.
OK, I think I found them. They don't have WS2811 but they have the WS2801 at a pretty decent price (about $0.50).
http://www.ebay.com/itm/160677261735
All I'd need is a PCB.
Maybe I can ask them if they can get the WS2811. Half the pins means a lot less soldering work and 8-pin SOP->DIP adapter PCBs are much cheaper than 14-pin. :)
Edit: I sent an email, let's see what he/she says...
fungus
As an aside ... could you even find it in SOP? I'm coming up blank.
johnwasser
Yes.
AliBaba.com (wholesale, typical minimum order = 1000 pieces)
AliExpress.com (smaller batches)
    For example: 100 units for $18.00 ($25.37 w/shipping to USA)
    http://www.aliexpress.com/store/product/100PCS-LOT-Original-WS2811-WS2811S-SOP-8/111482_726515440.html
fungus
#8
Feb 07, 2013, 07:06 pm Last Edit: Feb 07, 2013, 07:22 pm by fungus Reason: 1
Ok, that's pretty good.
I could get a batch of those and some of these to solder the chips/wires onto: http://www.ebay.com/itm/310575279861
...that seems like a working plan.
Thanks!
fungus
Just an update in case anybody else is interested in this:
The guy from eBay got back to me and he's got the WS2811 in DIP and at a reasonable price ($0.60 each in small quantities...)
That sounds quite expensive per-LED but they can really save a lot of work/wires, especially if the LEDs are far apart. You only need three wires between each RGB LED to make it work and the datasheet says you can have up to 20 meters between each one.
Plus ... you can drive any number of LEDs with only one Arduino pin. :)
CrossRoads
One pin? Don't the WS chips need clock & data?
Ah, I see WS2811 gets clock from the dataline.
fungus
That's the WS2801...
Yep. It's all down to careful timing.
(Or not-so careful...it's not really that fussy unless you're trying to send data as fast as possible)
