Topic: LED/Pressbutton woes (Read 4514 times) previous topic - next topic
Wildsky
In Chapter 4, Example 2, I've got my code and wiring exactly like the book describes, but my LED stays lit, and won't change whether I press the button or not. This seems really straightforward, other than the fact it doesn't work as expected. Any ideas what I'm doing wrong?
Chris
JimboZA
Quote
Perhaps you haven't....  8)
You should post the actual code here, copied from the ide not the book. Also post a diagram or clear photo of the actual circuit.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Wildsky
Absolutely, thank you!
// Hello world
const int LED = 13;
const int BUTTON = 7;
int val = 0;
  pinMode(LED, OUTPUT);
  pinMode(BUTTON, INPUT);
  val = digitalRead(BUTTON);
  if (val == HIGH) {
    digitalWrite(LED, HIGH);
  else {
    digitalWrite(LED, LOW);
JimboZA
I'm not at home where I have access to one of those switches and my multi-meter, but you might have that switch rotated by 90 degrees.
The wires might be on the links that are always connected, not across the "open" part which the switch closes. If you have a meter you can check, but in anycase just re-orientate it and see if that works.
JimboZA
#4
Feb 08, 2013, 02:05 pm Last Edit: Feb 08, 2013, 02:39 pm by JimboZA Reason: 1
I don't have one of those switches... thought I did  :smiley-yell:
But if you have a look at the Fritzing pic on this tut, it looks to me like your switch is the wrong way round?
The switch joins the pins on the same side when it's pushed, not the opposite pins which is more intuitive and is the way you have yours: if I'm right then your red and yellow are always joined, not switched.
Edit.... I dug around and these switches seem to be (or are similar to) Omron B3Fs. Have a look at the pic attached from their datasheet, which indeed shows that opposite pins are always connected, and pushing the button connects the pins on the same side; in fact connects all 4 pins.
hiduino
A good quick test to see if you have the switch the wrong way is to just pull it out and see if the LED goes out.  If it does go out then just rotate your switch 90 deg.
Wildsky
Yep, that was it! :)
Thank you!
JimboZA
Switch pin layout level: FAIL
