Topic: WProgram.h: No such file or directory (Read 221168 times) previous topic - next topic
nickgammon
Looks like the OP did not read or understand your reply, and decided to start a new thread in the hope that would help.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
salim_yilmaz
i tried to change WProgram.h to Arduino.h but i still get a error. i dont know, What else I need to change?
AWOL
Nothing. In reply #8, I downloaded the library, did the changes, and recompiled the example.
Did you save the files when you made the changes?
salim_yilmaz
awol i tried reply #8 probably max6675.h have a error.Can you try to max6675.h
AWOL
I'm sorry, I'm on my tablet now, and don't have access to the source I had earlier.
AWOL
OK, Difficult to see, but "WProgram.h" should be <WProgram.h>
nickgammon
I downloaded the three files you linked.
I copied the library files into my "libraries" folder and restarted the IDE.
I removed the #include <WProgram.h> from inside MAX6675.cpp.
I changed #include <WProgram.h> to #include <Arduino.h> inside MAX6675.h
Your example sketch compiled without errors.
Now, your turn.
nickgammon
What do you mean it "probably" had an error?
Read this before posting a programming question
Post your errors. Copy and paste. Don't say it "probably" had an error.
salim_yilmaz
i fixed problem.I would like to thank all of you
michinyon
If you READ the error message which you posted,    the bad include statement was in the sketch INO file  and not in the library H or CPP file.
So go to the INO  file  and replace the reference to WProgram.h  with  Arduino.h
Henrique29
You have to go into the .h and .cpp files and change "WProgram.h" to Arduino.h
Thank you, I made the change and it worked fine.
GoForSmoke
Banged my head on this for a while, the zip extracted the library folder with a Read-Only.
The files inside are not read only but because the Folder is Arduino ain't happy.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
PeterPenPencil
I am new to Arduino and I am having the same problem here in March 3, 2015
Airborne1
I'm new to Arduino to. I'm having exactly the same problem. I'm going to reread this tomorrow and try and figure it out once and for all. :smiley-confuse:
