Topic: Arduino RFID Module RDM630 Code (Read 4710 times) previous topic - next topic
ilovetoflyfpv
Hi Gang
I'm thinking of purchasing the following RFID Module;
http://www.ebay.com.au/itm/New-1pc-125-KHZ-EM4100-RFID-Card-Read-Module-RDM630-UART-Compatible-Arduino-/190769771688?pt=LH_DefaultDomain_15&hash=item2c6ac3b4a8&_uhb=1#ht_4786wt_978
I found the following example code;
Code: [Select]
This is a sample code for RDM630 RFID reader by Spekel(Spekel.se)
This work is licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
http://creativecommons.org/licenses/by-nc-sa/3.0/
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
char code[20];
int val = 0;
int bytesread = 0;
//create a Serial object RFID
SoftwareSerial RFID= SoftwareSerial(rxPin, txPin);
 Serial.println("Serial Ready");
 RFID.begin(9600);
 Serial.println("RFID Ready");
 pinMode(rxPin, INPUT);
 pinMode(txPin, OUTPUT);
 val = 0;
 bytesread = 0;
 while(bytesread < 12)
   // read 12 digit code
   val = RFID.read();
   if(val == 3)
   { // if header or stop bytes before the 10 digit reading
     break; // stop reading
   if(val != 2)
     code[bytesread] = val; // add the digit
     bytesread++; // ready to read next digit
     code[bytesread] = '\0'; // add the NULL
 if(bytesread >= 12)
 { // if 12 digit read is complete
   Serial.print("Tag: [");
   for(int i=0; code[i]!='\0' ; i++)
     Serial.print(code[i]);
   Serial.println("]"); //print the whole 13 bytes
I was wondering if someone could explain what the following two lines do;
Code: [Select]
and
Code: [Select]
specifically;
Quote
'\0'
Any help would be greatly appreciated.
Cheers
Jase :)
tack
The sketch is commented. It clearly tells you that /0 is adding the NULL terminator to the end of the bytes read.
All strings should be terminated with a NULL. If you use a chat array to read in bytes then you should terminate the string with a NULL. Therefore if you want to hold 20 characters, your char array would need to be 21 to hold the extra NULL to terminate the string.
The other bits just set a loop up to read each byte and add to the array, or read valid characters from the array until it encounters the NULL (/0) signifying the end of the string.
ilovetoflyfpv
Hi tack
Thanks for the reply. I'm starting to get it. Much appreciated.
Cheers
Jase :)
