Topic: SOLVED How is "adjustTime(adjustment);" command used ? (time library) (Read 7753 times) previous topic - next topic
dalai
I want to  send a command to my program ,so an hour or a day is added to timer.
Later those commands will be sent by the press of a button
Is this command ok ? adjustTime(hour()++);
Code: [Select]
#include <Time.h>
void setup()  {
 Serial.println("sending time to arduino");
 setTime(0,0,0,1,1,2000);
void loop(){
digitalClockDisplay();
void digitalClockDisplay(){
 Serial.print(day());
 Serial.print(" ");
 Serial.print(hour());
 printDigits(minute());
 printDigits(second());
 Serial.print(" ");
 Serial.print(" ");
 Serial.print(month());
 Serial.print(" ");
 Serial.print(year());
void printDigits(int digits){
  Serial.print(":");
 if(digits < 10)
   Serial.print('0');
 Serial.print(digits);
johnwasser
I think the 'adjustment' is in seconds.  If you want to adjust he time forward an hour, try an adjustment value of 3600.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
PeterH
You need to look at the documentation for the library, or the examples that come with it, or the source code implementation, to understand how to use the functions provided by the library.
johnwasser
Sadly, the documentation provides NO help.  Basically it says "use this function to adjust the time".  The Playground article also shows no examples that include adjustTime().
It should not be necessary to read the library sources for basic documentation, but all too often it is.  That's one of the drawbacks of community-supplied libraries.
PaulS
Quote
That documentation is never wrong, though:
Code: [Select]
void adjustTime(long adjustment){
  sysTime += adjustment;
dalai
Is posible to give me a practical exable for adding  1 minute or 1 hour  please ?
only the command
Thank you
dalai
I am trying to find exambles of that command  for 3 days.
I feal like retarded
dalai
adjustTime(10);
number "10" is in seconds.
Thank you for your answers
