Topic: Array of pointers to objects (Read 1 time) previous topic - next topic
raymadigan
I have a library, I use to implement a class system for my application, named tcDevice.  It has a complex instantiation method, but it isn't important to my question.
In my application I can have from one to 3 instances of the object and I want to create a global array of pointers to this class that I can fill in at a later time.
I have tried many options around
#define devCount 4
tcDevice *myDevices[devCount];
It seems it want to create the instances.  But I don't know enough to create them at this time.
Any help would be greatly appreciated.
nickgammon
That's hard to answer. Can you post a complete sketch that demonstrates this? That snippet doesn't prove much.
Quote
Oh? Seems to? Does? Doesn't?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
lefstin
Are you saying the constructor is called when you declare the array of pointers?
nickgammon
Code: [Select]
That doesn't create anything. It reserves some memory (for pointers, not instances of the object).
You might want to look up the "new" operator.
nickgammon
@OP: Please don't delete a thread once it has been answered.
