Topic: xbee.h will not compile with MICRO (Read 6978 times) previous topic - next topic
wlynn
I am trying to use the MICRO with Xbee but I get the error
error: cannot convert 'Serial_*' to 'HardwareSerial*' in assignment
I read the post about a fix for the LEONARDO as shown in:
But I still get the error. Is there another code for the MICRO that is different from the LEONARDO or am I missing something else that I have to put in the code. This is the code I added to the beginning of xbee.cpp
Code: [Select]
#if defined(USBCON)
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
What is "USBCON", where is it defined/used??
Appreciate the help.
Bill
wlynn
The url for the LEONARDO post is
http://arduino.cc/forum/index.php/topic,111354.0.html
Bill
PaulS
Quote
"I'm trying to compile a sketch, but I won't show you what sketch, for the MICRO, and I'm having problems. Can you help?"
Did I summarize your post correctly?
wlynn
Sorry about that; I was assuming the problem was in the xbee.h or xbee.cpp library files; anyway heres the core of the code.
Appreciate quick response and the help.
Code: [Select]
#include <Keypad.h>
#include <Button.h>
#include <XBee.h>
#include <AltSoftSerial.h>
#include <SoftwareSerial.h>
uint8_t LCDTxPin = 13;
SoftwareSerial mySerial = SoftwareSerial(255, LCDTxPin);
const int launch_A = 10;
const int launch_B = 11;
int buttonstate_A = 0;
int buttonstate_B = 0;
uint8_t count = 0;
uint8_t ncount = 0;
// Define AltSoftSerial TX/RX pins
// Connect Arduino pin 8 to TX of usb-serial device
uint8_t ssRX;
// Connect Arduino pin 9 to RX of usb-serial device
uint8_t ssTX = 9;
// Remember to connect all devices to a common Ground: XBee, Arduino and USB-Serial device
AltSoftSerial nss(ssRX, ssTX);
XBee xbee = XBee();
unsigned long start = millis();
uint8_t hset = 0x01;
// set payload to launcher ID;i.e hand station 1 and Station 1 and launcher 1
        // set payload to launcher ID;i.e hand station 8 and Station 15 and launcher 5
uint8_t payload []= {hset,0x01,0x01};
// Set DIO0 (pin 20) to Analog Input
uint8_t d0Cmd[] = { 'D', '0' };
uint8_t d0Value[] = { 0x4 };
uint32_t xbee_SH = 0x0013a200;
uint32_t xbee_SL = 0x40923f1f;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
  //MEMBRAIN KEYPAD
char keys[ROWS][COLS] =
  {1,2,3},
  {4,5,6},
  {7,8,9},
  {'*',0,'#'}
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int attempt[2]={0,0}; // used for comparison for statioID
char P_PIN[6]={1,2,3,4,5,6}; // our secret (!) number
char P_attempt[6]={0,0,0,0,0,0}; // used for password comparison
int z=0;
uint8_t key1;
uint8_t key2;
uint8_t StationID = 0;
uint8_t nStationID = 0;
char gotolauncher;
  pinMode(LCDTxPin, OUTPUT);
  digitalWrite(LCDTxPin, HIGH);
  pinMode(launch_A, INPUT);
  pinMode(launch_B, INPUT);
  digitalWrite(launch_A, HIGH);
  digitalWrite(launch_B, HIGH);
  Serial.begin(9600);          //MICRO USB serial
  //Serial1.begin(57600);        //xbee serialon pins 1,2
  xbee.setSerial(Serial1);
  // start soft serial for debugging
  nss.begin(9600);
  // start LCD serial
  mySerial.begin(9600); //start LCD serial
  mySerial.write(0x7c);
  mySerial.write(130);
void sendPacket()
     // SH + SL of your remote radio
  XBeeAddress64 remoteAddress = XBeeAddress64(xbee_SH, xbee_SL);
    // Create a remote AT request with the IR command
  RemoteAtCommandRequest remoteAtRequest = RemoteAtCommandRequest(remoteAddress, d0Cmd, d0Value, sizeof(d0Value));
    // Create a Remote AT response object
  RemoteAtCommandResponse remoteAtResponse = RemoteAtCommandResponse();
  sendRemoteAtCommand();
  nss.println("First Command");
delay(100);
void sendRemoteAtCommand() {
  nss.println("Sending command to the XBee");
  // send the command
  xbee.send(remoteAtRequest);
  // wait up to 5 seconds for the status response
  if (xbee.readPacket(5000)) {
    // got a response!
    // should be an AT command response
    if (xbee.getResponse().getApiId() == REMOTE_AT_COMMAND_RESPONSE) {
      xbee.getResponse().getRemoteAtCommandResponse(remoteAtResponse);
      if (remoteAtResponse.isOk()) {
        nss.print("Command [");
        nss.print(remoteAtResponse.getCommand()[0]);
        nss.print(remoteAtResponse.getCommand()[1]);
        nss.println("] was successful!");
        if (remoteAtResponse.getValueLength() > 0) {
          nss.print("Command value length is ");
          nss.println(remoteAtResponse.getValueLength(), DEC);
          nss.print("Command value: ");
          for (int i = 0; i < remoteAtResponse.getValueLength(); i++) {
            nss.print(remoteAtResponse.getValue()[i], HEX);
            nss.print(" ");
          nss.println("");
        nss.print("Command returned error code: ");
        nss.println(remoteAtResponse.getStatus(), HEX);
      nss.print("Expected Remote AT response but got ");
      nss.print(xbee.getResponse().getApiId(), HEX);
  } else if (xbee.getResponse().isError()) {
    nss.print("Error reading packet.  Error code: ");
    nss.println(xbee.getResponse().getErrorCode());
    nss.print("No response from radio");
    return ;
void getlauncher()
  //nss.println("I'm Here");
  switch(StationID)
    case 1:                              //Station #1
      buttonstate_A = digitalRead(launch_A);  //A launcher button pushed
      buttonstate_B = digitalRead(launch_B);  //B launcher button pushed
      if (buttonstate_A == LOW)
        nss.println("launch_A pressed");
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        xbee_SL = 0x40923f25;
        sendPacket();
        delay(10);
        payload[1] = 0x01;
        payload[2] = 0x01;
      if (buttonstate_B == LOW)
        nss.println("launch_B pressed");
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        xbee_SL = 0x40923f3d;
        sendPacket();
        delay(10);
        payload[1] = 0x01;
        payload[2] = 0x02;
    case 2:                              //Station #2
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        sendPacket();
        delay(10);
        payload[1] = 0x02;
        payload[2] = 0x01;
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        sendPacket();
        delay(10);
        payload[1] = 0x02;
        payload[2] = 0x02;
void readcounts()
  mySerial.write(254);  //cursor to beginning of first line
  mySerial.write(128);
  mySerial.write("StationID=     ");
  mySerial.write(254);  //cursor to position 12 of first line
  mySerial.write(139);
  mySerial.print(nStationID);
  mySerial.write(254);  //cursor to beginning of second line
  mySerial.write(192);
  mySerial.write("#launches=     ");
  mySerial.write(254);  //cursor to position 12 of second line
  mySerial.write(203);
  mySerial.print(ncount);
if (nStationID != StationID)
    readcounts();
    StationID = nStationID;
if (StationID == 0)
if (gotolauncher = '#')
    getlauncher();
if (StationID != 0 && StationID != 18 && StationID != 21)
if (StationID == 21)
if(StationID == 18)
if (ncount != count)
   readcounts();
   count = ncount;
PaulS
Code: [Select]
uint8_t ssRX;
uint8_t ssTX = 9;
You don't think the compiler is going to read your comment, do you?
Why isn't ssRX assigned a value?
Complete error messages are a good thing,
wlynn
I am not using pin 8 for serial; I am only using Pin 9 for debugging.
This code works fine on PRO MICRO and FIO. It will not compile when MICRO is selected.
The error code I get when connected to MICRO is:
Quote
RemoteAtCommand_DIGIMESH_MICRO_xbee.ino: In function 'void setup()':
RemoteAtCommand_DIGIMESH_MICRO_xbee:79: error: no matching function for call to 'XBee::setSerial(Serial_&)'
C:\Documents and Settings\BILL\My Documents\ARDUINO_1_16_2013\arduino-1.0.3\libraries\XBee/XBee.h:779: note: candidates are: void XBee::setSerial(HardwareSerial&)
Bill
PaulS
Quote
I don't understand this. You should still assign a non-zero value to the ssRX pin.
Where did you get the XBee library you are using?
wlynn
The Xbee library is xbee-arduino-0.4-softwareserial-beta.zip downloaded from here;
http://code.google.com/p/xbee-arduino/
The program runs fine with nothing assigned to the ssRX pin.
Bill
PaulS
When I compile your code, for the Micro, using 1.0.3, I get a number of errors about AltSoftSerial not being configured for the Micro, but I get no errors about the XBee library. What version of the IDE are you using? How did you configure AltSoftSerial to recognize the Micro?
wlynn
I let you to the wrong xbee.h file ; the one I am using I got from:
http://code.google.com/p/xbee-arduino/issues/detail?id=20
I am using the one from the March 9, 2012 post. This included the support for DIGIMESH.
Sorry.
I am using Arduino 1.0.3
Bill
wlynn
Paul:
Hold off spending any more time at the moment; I have screwed up my files and I have to straighten them out before I ask for more assistance.
I will repost when I can figure out what changes I made to xbee.h
Bill
wlynn
Paul
OK, back on track.
Attached are the xbee.h, xbee.cpp and error message., xbee.h and xbee.cpp were downloaded from
http://code.google.com/p/xbee-arduino/issues/detail?id=20 March 9 post.
The sketch runs OK with FIO or PRO MINI but gives the error message when using a MICRO.
Bill
PaulS
In those files, the _serial member is a HardwareSerial pointer. In the XBee library at http://code.google.com/p/xbee-arduino/, the _serial member is a Stream.
Both HardwareSerial and Serial_ derive from Stream, but are not interchangeable. The XBee library does not rely on the parts of HardwareSerial or Serial_ that distinguish them from Stream. So, just use the library from the google link.
wlynn
I cannot use this solution since I am using a Xbee DIGIMESH and it will not work with the beta XBee library downloaded from here
This library works with Xbee series 1 and 2 but not all API packets for DIGIMESH
The Xbee library downloaded from here
works with DIGIMESH but not with ARDUINO MICRO.
I fixed my sketch by combining the two zbee libraries into a third which I call XBeeDM32u4 and this is now working with the MICRO and a Zbee DIGIMESH 2.4Mhz.
Attached is the new library; I do not know iof this will work for everyone but it fixed my sketch.
Bill
wlynn
Here is the XBeeDM32u4.h file
Bill
