Topic: 555 timer beginner circuit help (Read 9623 times) previous topic - next topic
funkyguy4000
Hello,
I am the IEEE Project Coordinator at my university and I am trying to teach beginners to electronics the concept of bread-boarding and how to use the 555 timer.
Now I consider myself a pretty knowledgable person in electronics and this is why I'm kind of annoyed.
I was going to show them this circuit , http://www.555-timer-circuits.com/bi-polar-led-driver.html but for some reason it just isn't running. I have it wired up like the image but it just won't run!
Any help?
Accelerate to 88 miles per hour.
TeslaIaint
Have you tried swapping parts out or even swapping out the breadboard? I know from my school days that students often put bad parts back in the parts drawers. It shouldn't take long to completely start over with new parts.
funkyguy4000
Yup, everything has been tried with new parts, even the power supply
cmiyc
Make sure the 33K is connected to output, not 9V.
nickgammon
I made up that exact circuit, and it worked. Both LEDs flashed. Only one flashed when powered with 5V.
What do you mean? No LEDs flash? Just one? One or both on all the time?
funkyguy4000
Roger that, yuuup its connected properly
Nothing happens.  No flash, no nothin.
any other ideas?  Maybe the diagram is wrong?
nickgammon
How could it be wrong if I just got it to work?
Maybe post a clear photo.
funkyguy4000
What?! Really?  Maybe I'm not as good a breadboarder as I thought I was.
I should point out that I don't have a bi-color led like the thing says, so I'm just using two leds set up like the diagram.
This is the best picture I can get.
nickgammon
That's what I had.
It looks to me like you have something connected to pin 5, which is NC on the diagram.
Is that 10 uF cap in the right way? It looks not, from the photo.
funkyguy4000
Hmm don't know how that wire got there.
After I removed it, I switched the cap around.  Still doesn't work.
nickgammon
This is my setup, which works:
funkyguy4000
Hmm, well now I have it working! I'll look over the diagram to see what I did wrong.  Thanks a bunch!
funkyguy4000
Interesting....
When I connect up the 2nd led in the backwards direction with the resistor going to GND. the whole circuit turns off. I thought that those two resistors might just be shorting out the whole circuit.
Is that whats going on?
silverxxx
the led is probably shorted out.
nickgammon
