Topic: i want to replay the sound (Read 6874 times) previous topic - next topic
mostafa_zied
this code is for a project used the RFID & SD cards to made an simple audio play for one id
i use tags with ID's
it's work good
but for one time not work as a loop!!!!
when i near the rfid card to the reader it's work a one of the play samples
but for one time >>>>>> and i need to replay  the arduino
#include <PN532.h>
#include <SPI.h>
#include <SimpleSDAudio.h>
#define PN532_CS 10
PN532 nfc(PN532_CS);
#define NFC_DEMO_DEBUG 1
#ifdef NFC_DEMO_DEBUG
#endif
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
#endif
while (1); // halt
#endif
nfc.SAMConfig();
void loop(void)
uint32_t id;
id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
if (id != 0)
Serial.print("Read card #");
Serial.println(id);
if(id==4251492471)
if (SdPlay.init(SSDA_MODE_FULLRATE | SSDA_MODE_MONO))
if(SdPlay.setFile("12.afm"))
SdPlay.play();
while(!SdPlay.isStopped())
SdPlay.worker();
#endif
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
mostafa_zied
sorry what you mean by tage ??
Tuttut
please use the line if (SdPlay.init(SSDA_MODE_FULLRATE | SSDA_MODE_MONO)) only once at setup.
mostafa_zied
ok>>>>> but shat about ""if""?????????
nickgammon
What about the code tags? And please use the auto-format tool in the IDE. This sort of stuff is impossible to follow:
Code: [Select]
#endif
Quote
Do you mean "tags"? Read this: How to use this forum
There is a pretty clear screen-shot showing what I mean.
mostafa_zied
Code: [Select]
#include <PN532.h>
#include <SPI.h>
#define PN532_CS 10
#endif
nfc.begin();
#endif
while (1); // halt
#endif
nfc.SAMConfig();
void loop(void)
uint32_t id;
if (id != 0)
Serial.println(id);
if(id==4251492471)
SdPlay.play();
SdPlay.worker();
#endif
mostafa_zied
thanx ........ this is the code
nickgammon
mostafa_zied
nickgammon
Here, let me format it for you:
Code: [Select]
#include <PN532.h>
#include <SPI.h>
#define PN532_CS 10
#endif
  nfc.begin();
#endif
    while (1); // halt
#endif
  nfc.SAMConfig();
void loop(void)
  uint32_t id;
  if (id != 0)
    Serial.println(id);
    if(id==4251492471)
          SdPlay.play();
            SdPlay.worker();
#endif
nickgammon
This is confusing:
Code: [Select]
#endif
What's the point?
I'll get rid of all the #ifdef:
Code: [Select]
#include <PN532.h>
#include <SPI.h>
#define PN532_CS 10
  nfc.begin();
  if (! versiondata)
    while (1); // halt
  nfc.SAMConfig();
} // end of setup
void loop(void)
  uint32_t id;
  if (id != 0)
    Serial.println(id);
    if(id==4251492471)
          SdPlay.play();
            SdPlay.worker();
You have this:
Code: [Select]
    Serial.println(id);
But no Serial.begin.
OK, now we can read the code, what is the problem exactly?
I don't understand this:
Quote
it's work good
mostafa_zied
i mean that >>> the program should made an audio output every time i near the rfid card
but in this code it's search for the card successfully and made an audio output successfully but when the audio ended it's doesn't search about the card again !!!! so i need to made the program to search again without restarting the board from the button
nickgammon
RFID card readers typically return a single response for one card, and then don't "notice" that card until it moves away and comes back.
