Topic: Arduino Uno R3: What is the maximum output amperage? (Without damaging board) (Read 28273 times) previous topic - next topic
Arkafan
I did not find this statistic on the Arduino main website.
I am doing a project in which multi-colored LEDs are wired in parallel (each color gets a port, same port for all LEDs) which means I am using 3 digital output ports. (One for R, one for G, one for B (RGB)).
Each LED draws 30 mA. As I am typing this, 3 LEDs are glowing normally.
What is the maximum amperage I can draw through the Arduino Uno? Will I burn the board if I have 15 LEDs?
Thanks,
Ark
nickgammon
Summary:
http://www.gammon.com.au/uno
The datasheet is the final reference, but my link above should be close enough.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Arkafan
Thank you.
Looks like the Uno itself won't suffice, but I can always program it to run a power supply and/or transistor.
Thanks,
-Ark
nickgammon
Code: [Select]
15*30 = 450
That exceeds the maximum for the chip, plus you are drawing more than the recommended amount per pin. A few transistors might be in order.
See datasheet, page 314:
Quote
Although each I/O port can source more than the test conditions (20 mA at VCC = 5V, 10 mA at VCC = 3V) under steady state conditions (non-transient) ...   Pins are not guaranteed to source current greater than the listed test condition.
efifi
Hi
My first post.
I just bought an UNO as well as some adafruit led strips.
The led strips advise the following current current requirements
60 NeoPixels × 20 mA ÷ 1,000 = 1.2 Amps minimum - not all leds on, or dimmed
60 NeoPixels × 60 mA ÷ 1,000 = 3.6 Amps minimum - all leds on bright
Not having a clue what i was doing, i proceeded to plug a strip with 120 leds into the 5+ VCC and group pins of the UNO.
By all rights this should be drawing 7.2 Amps - 120 * 60.
All leds are on full brightness - how is this even possible without damaging the UNO?
I did this for 2 weeks, until I did more reading - now i am terrified to plug the strip back into the ardunio - of course this poses the next problem - a 5V power supply with 10 Amp - but thats another story.
I would like to understand why the leds worked and what i am doing to the arduino.
thanks for your help and patience.
Thanks
Clive
"If I have seen further than others, it is because I have stood on the shoulders of giants." - Isaac Newton
You are my giants........
CrossRoads
The neopixel are powered from the 5V header pin, yes? They only receive signal from the 328P, so no damage there. Kinda surprised you didn't smoke the 5V regulator, which is only rated for 800mA.
JimboZA
That was going to be my question: assuming the LEDs are only controlled, not powered, by the I/O, what current can the board supply at the 5V pin.... the OP seems an order of magnitude over the allowable so that regulator must be glowing.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
efifi
Thanks for the rapid response
Correct - The neopixel are powered from the 5V header pin - the data pin sends the signal.
"Kinda surprised you didn't smoke the 5V regulator, which is only rated for 800mA." - so, i guess I should thank my lucky stars I got away with this and not try it again.
The question still remains - how did i get away with it? It indicates the regulator has a massive tolerance
CrossRoads
No idea, unless it is not drawing the current you think it is.
The reverse polarity protection diode is only rated for 1A, seems kind of unlikely that both devices would survive an overcurrent condition like that for so long.
