Topic: How to reset Mega 2560 R3 (Read 21255 times) previous topic - next topic
RichardU
I tried a program which was installed by entering the following line at a command prompt.
   C:\arduino-1.0.3\hardware\tools\avr\bin\avrdude -patmega2560 -cwiring "-P\\.\COM7" -b115200 -Uflash:w:apduinos-headless.hex:a "-CC:\arduino-1.0.3\hardware\tools\avr\etc\avrdude.conf"
Frankly, I don't quite understand what this does, but I want to get my Mega R3 back to factory/stock/default condition. I would appreciate any advice on how to do that.
johnwasser
If the processor has not had the Reset or Serial Programming fuses set to disabled you should be able to reset your Arduino to factory settings with your choice of ISP device.  Just select the programmer (Tools->Programmers) the board type (Tools->Board->Arduino Mega 2560) and select Tools->Burn Bootloader.
You can buy a USBasp programmer for under $4 on eBay. Most come with only a 10-pin cable so you should either look for one that includes a 6-pin cable or get a 10-pin to 6-pin adapter for about $3 on eBay.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
nickgammon
Let's assume the OP has one of those, or he wouldn't have been able to replace the bootloader.
If you upload this .hex file (below) it should put the bootloader back.
https://github.com/arduino/Arduino-stk500v2-bootloader/blob/master/goodHexFiles/stk500boot_v2_mega2560.hex
(You probably need to go to that page, RH-click on the Raw button, and save the file appropriately).
You should also have the original bootloader on your disk in the "bootloaders" folder, named "stk500boot_v2_mega2560.hex". However the one that ships has a bug, I believe, with the way it handles watchdog timeouts.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
retrolefty
Quote
Correct, plus it barfs the upload if the flash contents has three !!! in a row.
Lefty
RichardU
Thanks guys. I only have a USB cable (no ISP device). So I'm guessing the command prompt code I executed has not affected the bootloader, which would mean I am still in stock condition.
nickgammon
Yes, unless you had a second Arduino and connected them together in such a way that one programmed the other.
