Topic: NRF24L01 failing. Placing finger on aerial fixes it! (Read 4617 times) previous topic - next topic
AlanC
I am new to this and am trying to use NFRT4L01 units to communicate.
I have built two boards and am using simple ping code to bounce a message between two units. I have found it is unreliable. However I can normally get it to work by placing my finger on the end of the antenna (the antennae is internal to the Printed Circuit Board). It seems to be the transmit that is failing (i.e. placing my finger on unit A causes Unit B to start receiving)
It seems that different combinations of chips work better than others, even though they are all supposed to be the same.
Units fail whether they are 2 cms or 10 metres apart, so I am presuming it is not signal strength.
Is there something I am missing? Would I be better using a units with aerials?
AlanC
I am new to this game and tried posting this 15 minutes ago, but can't find it. Apologies if it is a duplicate.
I am trying to set up comms between two Arduinos using NRF24L01 chips.
I found some testing code and wired up two units. One sends a message, the other receives it and sends it back.
I have found it is unreliable. However I can normally get it to work by placing my finger on the end of the antenna (they are on the surface of the printed circuit board). It seems to be the transmit that is failing (i.e. placing my finger on unit A causes Unit B to start receiving)
Am I missing something? Would I be better using a units with aerials?
oric_dan
Failing = NOT. What you have sounds about right. I just went through this a week ago.
These units have only 1 mW transmit power, and 10m will be about the outer limits in
usable range. And at 2 cm, the receiver is probably being overloaded.
http://arduino.cc/forum/index.php/topic,151145.msg1139300.html#msg1139300
Ways to get better range are: get 50 mW units [eg, XBee Pros], get something with a
1/4 wave whip or 1/2 wave dipole antenna, go to a lower frequency band, such as 433 Mhz.
Coding Badly
Grumpy_Mike
Quote
Yes it is signal strength.
AlanC
Hi, Thanks for the quick response.
The comments suggest that at 2 cms it fails because it is overloaded and it fails at 10 metres because it is too weak. This would suggest that it should work at some distance in between. However at every distance I try it only works if I have my finger on the aerial.
Alan C
Grumpy_Mike
Quote
Yes but if it is not the case that the receiver is overloading, then it is a simple case of just not enough signal. Which is what it sounds like to me.
What about your ground levels? Have you tried putting it on a ground plane.
Nick_Pyner
There has been recent discussion about this around here. It appears that the range can be substantially increased by reducing the data rate. 256k I think.
oric_dan
Oh, it fails at every distance. That means either: (a) the modules are bad, (b) the Vcc
power is bad, (c) the wiring is incorrect, (d) the signal levels are incorrect, or (d) the
software is incorrect.
First, check (b), better be 3.3V only. Then check (c), wIth 8 wires, it's a good chance
something is miswired. Then check (d), better be 3.3V only. One can only guess at what
hardware and interfaces are being used.
Then verify the pin callouts in the s.w. being used match the wiring, and and one can only
guess what s.w. is being used.
A lot of guessing here, not much information.
Docedison
Put a 47 uF and a .1 uF capacitor right on the 3V3 Vcc connections at the radio board. Should fix some of your problems, likely something is oscillating in the receiver... and the effects of your finger change enough of the receiver to cause it to work... It's very possible that that issue is due to no/faulty power supply by-passing.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
Grumpy_Mike
KirAsh4
Note that Nordic Semi does not suggest using the nRF24L01 anymore, instead use the nRF24L01+ ...  Having said that, I did a project two years ago with some nRF24L01+ using stub antennas and I was able to get 30-50+ meter distance between modules (at 512 kbps).  Near clear line of sight.  The modules were attached on people's shoulders with the stub antenna sticking up.  In a group of 20, I didn't have any problems communicating in a single master, multiple slaves setup.
tomward
Mr AlanC - did you ever find what was causing this?  I've found the same problem.  With my tests it seems to be much worse when you increase the TX power.  Also some modules seem to be worse than others although all of the 'black PCB' ones I've tested seem to be problematic.  Decoupling doesn't seem to help.
Tom
