Topic: Nuovi sviluppi IDE 1.8.x (Read 480017 times) previous topic - next topic
PaoloP
Se guardi su github in Arduino c'è un ramo di sviluppo relativo alle librerie via URL.
--> https://github.com/arduino/Arduino/tree/ide-1.5.x-import-library-from-url
lestofante
sì, loro tendono a sviluppare le cose in rami diversi e poi mergirli alla fine. Sopratutto se sono modifiche proposte dagli user.
Guida per principianti http://playground.arduino.cc/Italiano/newbie
Unoffical Telegram group https://t.me/genuino
PaoloP
#62
Apr 16, 2013, 09:33 pm Last Edit: Apr 16, 2013, 09:39 pm by PaoloP Reason: 1
Ho appena notato che nella pagina del Download (http://arduino.cc/en/Main/Software) ci sono le Nightly Builds. :smiley-mr-green:
Quote from: Revision.txt
ARDUINO 1.5.3 BETA
[ide]
* Removed useless baud rates from serial monitor
* Fixed some minor IDE UI bugs (Shigeru Kanemoto)
* Added support for new 1.5 Library format (https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5:-Library-specification)
* Pass board type from boards.txt (https://github.com/arduino/Arduino/issues/308)
[arduino core]
* sam: Fixed delayMicrosecond() when interrupts are disabled
* sam: Upgraded libsam, and added missing modules (CAN, ETH, etc.) (Thibaut Viard)
* sam: Added compatibility for avr/pgmspace.h (Paul Stoffregen)
* sam: Added serialEvent*() support
[libraries]
* sam: Added CAN library (still in early stage of development) (Palliser)
[firmwares]
* Arduino Due: fixed USB2Serial garbage at startup (https://github.com/arduino/Arduino/pull/1267)
ARDUINO 1.0.5 - 2013.03.29
[core]
* [avr] malloc bug: backported avr-libc 1.8.0 implementation
* [avr] removed deprecated interrupt handlers causing compiler issues
  with newer avr-gcc.
[libraries]
* Upgrades to WiFi library
[firmwares]
* Upgrades to WiFi firmwares
Madwriter
sei bravo sì  :P praticamente un genio. Può essere che l'errore si riferisse all'accrocchio, in questo caso avevi comunque caricato il bl prima. Non so dirti se sono normali quei flashing, ma se gli sketch si caricano e funziona tutto, non vedo che problemi dovresti avere.
ebbbbbravo guagliò XD
per andTrea anche io ho lo stesso programmatore è un errore standard ignoralo  :smiley-mr-green:
funziona alla perfezione  ;)
"Due cose sono infinite: l'universo e la stupidità umana, ma riguardo l'universo ho ancora dei dubbi..." Albert Einstein
leo72
@PaoloP:
ti consiglio la compilazione da sorgenti, è la via più facile per avere sempre la versione più aggiornata disponibile.
Una volta scaricati i sorgenti, io compilo in circa un minuto. Mi ci vuole un po' di più per il ramo 1.5 perché scarica della roba per il sam da internet (e sono diversi mb di roba).
busco
@PaoloP:
E' una tecnica che non conosco.
Posso chiederti di descrivere come procedere?
Uso ubuntu.
Grazie
lestofante
usa le nighty build scaribabili dalla home page sezione download.
nid69ita
E cosa sono? Sulla pagina non c'e' nessuna spiegazione. Se clicchi fa che scaricare uno zip.  :smiley-eek:
my name is IGOR, not AIGOR
busco
Grazie
OK
astrobeed
nighty build
Piccolo quiz, lo sapete perché si chiamano così le release più recenti, in beta, dei programmi ?
Scientia potentia est
busco
Sono queste:
Nightly Builds
    Windows
    Mac OS X
    Linux: 32 bit, 64 bit
busco
nighty build
Perchè vengono aggiornate di notte.
lestofante
sono le "ricompilazioni notturne", ovvero ogni notte un programmino ricompila i sorgenti attuali e prepare l'ide. In pratica è quello che fa leo, ma già fatto in automagico.
Hai il vantaggio che scarichi ed usi, hai lo svataggio che non hai i sorgenti, quindi non puoi fare modifiche all'IDE.
astrobeed
No, non è questa la risposta corretta, e non è vero che vengono compilati la notte anche se magari per questioni di fuso orario può sembrare così.
Il vero motivo per cui c'è questo nome affonda nelle radici dell'informatica quando non esistevano ancora  i pc e i programmi si caricavano su i computer tramite nastri e/o schede perforate.
All'epoca per fare una compilazione servivano molte ore, a volte anche giorni, per questo motivo i programmatori durante il giorno preparavano le nuove routine, o le modifiche a quelle già esistenti, e durante la notte venivano date in pasto ai mainframe dell'epoca che provvedevano a compilarle fornendo la lista degli errori in tempo per il giorno lavorativo seguente.
nid69ita
Sono queste:
Nightly Builds
    Windows
    Mac OS X
Ok, ma come mai @Leo ha una immagine con ARDUINO 1.0.5 e nel txt postato da @Paolo c'e' ARDUINO 1.0.5 - 2013.03.29
mentre Arduino Nighty (le ho scaricate) visualizzano Nighty?  Sulla pagina del download ufficiale, non trovo nulla su 1.0.5
Guardo nel posto sbagliato?
