Quote from: lesto on Mar 11, 2013, 06:30 pm QUETSO! -----> Fixed malloc bug <------ è il vero bug fix della versioneOpinione personale, usare la malloc su un sistemino basato su una modesta mcu 8 bit con 2k di ram è come pestarsi le dita con una mazza da 5 kg
ARDUINO 1.0.5 - 2013.05.15[core]* [avr] malloc bug: backported avr-libc 1.8.0 implementation* [avr] removed deprecated interrupt handlers causing compiler issues with newer avr-gcc.* [avr] added c_str() method to String* [avr] Stream "_timeout" field and related methods are now protected[libraries]* Upgrades to WiFi library* Fixed a bunch of examples[firmwares]* Upgrades to WiFi firmwares[ide]* Backport from 1.5: install Library from .zip file or folder* Added button "Copy error to clipboard" (Paul Stoffregen)* Updated windows drivers* Added Windows installer
Fork dell'IDE con procedura di installazione e qualche opzione in pi?.--> http://arduino.cc/forum/index.php/topic,118440.0.html
ARDUINO 1.5.3 BETA[ide]* Removed useless baud rates from serial monitor* Fixed some minor IDE UI bugs (Shigeru Kanemoto)* Added support for new 1.5 Library format (https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5:-Library-specification)* Pass board type from boards.txt (https://github.com/arduino/Arduino/issues/308)* Display estimated RAM usage after compile (Loren M. Lang)[arduino core]* sam: Fixed delayMicrosecond() when interrupts are disabled* sam: Upgraded libsam, and added missing modules (CAN, ETH, etc.) (Thibaut Viard)* sam: Added compatibility for avr/pgmspace.h (Paul Stoffregen)* sam: Added serialEvent*() support* sam: Fixed micros() to work with inside interrupts. (stimmer)* avr: Added support for Flash strings on String class (Jantje)* Added support for floating point numbers in String class (Tevin Zhang, SebiTimeWaster)* sam: Fixed String buffer overflows (Paul Stoffregen)[libraries]* sam: Added CAN library (still in early stage of development) (Palliser)[firmwares]* Arduino Due: fixed USB2Serial garbage at startup (https://github.com/arduino/Arduino/pull/1267)[other]* Merged all improvements made in Arduino IDE 1.0.5
Per me questo fork è praticamente obbligatorio. Nella versione Windows sia di Arduino che di Energia (l'IDE clone dell'Arduino per l'MSP430 e lo Stellaris della Texas Instruments) c'è un problema con l'enumerazione delle seriali se il computer ha il bluetooth oppure ha usato un dongle bluetooth. Ci vogliono circa 30 secondi per lanciare l'IDE e accade la stessa cosa appena si usa il menù tools.Questa invece parte rapida come dovrebbe essere.
No, la 1.0.x è una schifezza, stessa cosa vale per le 00xx e la 1.5.x
