Topic: Binary counting using 12 LEDs (Read 21260 times) previous topic - next topic
littlewolf
My suggestion (which you've seen stated here by others more than once) is to CLEARLY define your requirements.
The reason I'm trying to use "millis" is because when using "delay" the keypad
reads the input only once then does nothing.
I am trying to use the keypad to control the binary counting on LEDs.
There are number keys (0,1,2,3,4,5,6,7,8,9) and operator keys (* and #).
I want to use the operator keys to either increase (pressing #) or decrease
(pressing *) the binary counting by the value of the number keys pressed.
Perhaps it would be nice to read two number keys at the time (going up to 99)
followed by an operator key.
To make it even more simpler:
2+5+'#' would count up by 25 (in binary)
I will try your last suggestion and also "HasardsMind's" suggestion.
In fact I'm working now on them.
I'll let you know about my progress.
Regards
littlewolf
I think I made the matter worse.
The topic suggested by "HazardsMind" is not very useful.
I changed the if statements as suggested by "lloiddean"
and I think it should be fine. Then, I tried to add the first two keys
together and to store the result into the "sum".
Now, I get instead very big numbers instead (for example 9+9= 114 ).
The LEDs don't blink any more and I am not very sure about the loop
for getting the third key.
This is my code:
Code: [Select]
/* Binary counting using 12 LEDs and a keypad to control
the increasing or decreasing rate by the value
of the key pressed*/
#include <Keypad.h>
int ledPin[12]={13,12,11,10,9,8,7,6,5,4,3,2};
int number=0;
int keyPressed=0;
int counter=0;
int sum=0;
char firstKey;
char secondKey;
long previousMillis = 0;
long interval = 1000;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {31, 33, 35, 37}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {39, 41, 43}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
   for(counter=0; counter<12; counter++)
  pinMode(ledPin[counter], OUTPUT);      // sets the digital pins as output
void loop(){
  char key = customKeypad.getKey();
  /*if (key) {
    Serial.println(key);
  if (key) { // blocking from anything not needed
   keyPressed= keyPressed+1;
   if (key != '*' && key !='#'){
    number =key - '0' ; // convert key to its value
  } // end of sort
   if (keyPressed ==1){
     firstKey=key;
  else if ( keyPressed==2){
    secondKey=key;
    sum=firstKey+secondKey;
  Serial.println(sum);
  //Serial.println(number);
  if (keyPressed==3){
   keyPressed=key;  // I'm not sure about this loop
    if (key == '#') // increment binary counter
       Serial.println("i"+firstKey);
       //digitalWrite(13, HIGH);
       //delay (1000);
     for(counter=0; counter< number; counter++){
      //digitalWrite(ledPin[counter-1], HIGH);
      digitalWrite(ledPin[counter], HIGH);
       if(currentMillis - previousMillis > interval) {
      } // end of millis
     } // end of increment counter
    } // end of '#'
    else if (key == '*') // decrement binary counter
      for(counter; counter < number; counter-- ){
        if (counter < 0) counter = 0; // checks to see if
        // counter does past zero then set it back to zero
      digitalWrite(ledPin[counter], LOW);
      } // end of millis
      } // end of decrement counter
    } // end of '*'
    } // end of keyPressed == 3
    keyPressed=0;
   } // end of keycount
  } //end of if(key)
} // end of loop
spatula
Guess what the ASCII value of '9' is? 57. In
Code: [Select]
you are adding the characters ('0'..'9'), not the numbers (0..9).
littlewolf
Code: [Select]
You are right.
I managed to do the code for addition.
Code: [Select]
#include <Keypad.h>
int number1=0;
int number2=0;
int keyPressed=0;
int counter=0;
int sum=0;
char firstKey;
char secondKey;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
void loop(){
  /*if (key) {
  // number =key - '0' ; // convert key to its value
  } // end of sort
     number1= key - '0';
     firstKey=key;
    number2= key - '0';
    secondKey=key;
    sum=(number1 *10)+number2;
  if (sum){
       //delay (1000);
     for(counter=0; counter< sum; counter++){
      } // end of millis
    } // end of '#'
      for(counter; counter < sum; counter-- ){
      } // end of millis
    } // end of '*'
    } // end of sum
    keyPressed=0;
  } //end of if(key)
} // end of loop
Now, when I press two numbers I get the right sum on the serial monitor.
However, if I press '*' I get minus 6. Similarly, for '#' I get minus 13.
How do I convert the third key to either increase the decrease the counting?
At the moment my LEDs don't do anything.
I also have to convert the input to binary counting.
How do I do it?
Regards
HazardsMind
The reason your getting -6 and -13 for # and * is beacuse you took out,
Quote
  } // end of sort
This part was making all the button work correctly. Try to do include this with "keyPressed ==1" and "keyPressed ==2".
Also that link I gave works fine. Im guessing you didn't fully understand it, no problem though. Your method will suffice.
littlewolf
How do I get then the sum If I put it back?
It doesn't work.
For the sum I need:
Can I do it differently?
HazardsMind
Code: [Select]
if (key != '*' && key !='#' && keyPressed ==1 ){
     number1= key - '0';
     firstKey=key;
Repeat for second key press
littlewolf
Thanks,
It works but I can only press two number keys at the time.
If I press either * or # it stops everything
The * and # keys still don't do anything and the counting doesn't start.
Now, what next?
HazardsMind
#38
Apr 03, 2013, 05:32 pm Last Edit: Apr 03, 2013, 05:34 pm by HazardsMind Reason: 1
According to your code, you have everything inside keypress2, and with the "key != '*' && key !='#' ", it will never get to the other buttons. You need to fix your brackets. Keypress1 is fine, now do the same thing for Keypress2. You can keep the sum inside, but everything else must come out.
Im not home right now, nor did I bring my stuff with me to work.
littlewolf
#39
Apr 03, 2013, 07:47 pm Last Edit: Apr 03, 2013, 07:49 pm by littlewolf Reason: 1
Thanks,
I really don't know how to close that bracket or more exactly, where is
the right place to put it. It shows me lots of errors.
Look, this is my modified code:
Code: [Select]
#include <Keypad.h>
int number1=0;
int number2=0;
int keyPressed=0;
int counter=0;
int sum=0;
char firstKey;
char secondKey;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
void loop(){
 /*if (key) {
 } // end of sort
  if (key != '*' && key !='#'&& keyPressed ==1){
    number1= key - '0';
    firstKey=key;
   } // end of key==1
 else if (key != '*' && key !='#'&& keyPressed==2){
   number2= key - '0';
   secondKey=key;
    // end or key==2
 if (sum){
      //delay (1000);
     } // end of millis
   } // end of '#'
     } // end of millis
   } // end of '*'
   } // end of sum
   keyPressed=0;
  }//end of if(key)
 }// end of loop
If I close the bracket after "end of key==2", see above, I also
have to close the loop which is worse.
I've been trying since this morning.
I really don't know
HazardsMind
This is not needed.
Quote
if (sum){
Once you enter the two numbers, it should add them, then go back and allow you to enter # or *.
Code: [Select]
    number2= key - '0';
    secondKey=key;
}// done with else if
lloyddean
#41
Apr 03, 2013, 08:16 pm Last Edit: Apr 03, 2013, 08:22 pm by lloyddean Reason: 1
I say again this code ...
Code: [Select]
if ( currentMillis - previousMillis > interval )
... performs absolutely NO USEFUL PURPOSE and might as well be replaced with ...
Code: [Select]
// WHAT ARE YOU LOOKING AT, NOTHING TO SEE HERE CARRY ON
... or, a lot less typing ...
Code: [Select]
Then I have qqusestion about this ...
Code: [Select]
else if ( key == '*' )
    for ( counter; counter < sum; counter-- )   // << DOES COUNTER HAVE A USEFUL VALUE HERE
HazardsMind
This is what I originally gave you.
Quote
      for(counter; counter > number; counter--) {
        if(counter < 0) counter = 0; // checks to see if counter does past zero then set it back to zero.        digitalWrite(ledPin[counter], LOW);
        delay (1000);
      }  // end of dec counter
  } // end of '*'
littlewolf
Hi guys,
I modified the code again following the last suggestions.
It compiles but doesn't work when I connect the circuit.
This is my code:
Code: [Select]
#include <Keypad.h>
int number=0;
int number1=0;
int number2=0;
int keyPressed=0;
int counter=0;
int sum=0;
char firstKey;
char secondKey;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
void loop(){
  /*if (key) {
  } // end of sort
     number1= key - '0';
     firstKey=key;
    } // end of if
    number2= key - '0';
    secondKey=key;
  }// end of else if
       //delay (1000);
    } // end of '#'
      for(counter; counter > number; counter-- ){
    } // end of '*'
    keyPressed=0;
   }//end of if(key)
  }// end of loop
What is wrong now?
It doesn't show any character on serial monitor
and the LEDs don't blink.
I have a question for "HazardsMind".
Should I use sum or number in counter loop?
Since I used sum = (number1*10)+number2,
perhaps is better to use sum.
What else is missing from this code?
Thank you everyone for your help.
Regards
HazardsMind
#44
Apr 03, 2013, 09:58 pm Last Edit: Apr 03, 2013, 10:12 pm by HazardsMind Reason: 1
No longer needed.
Quote
  } // end of sort
Take out "else" from here:
Quote
    number2= key - '0';
    secondKey=key;
  }// end of else if
Add serial.println(sum);
Right now your LEDs will only light up, not blink. You need to learn how to use the millis() timer properly.
Look into the blink without delay sketch.
