Topic: Help with code (Read 2337 times) previous topic - next topic
desmondttm123
Hello, i have an icomsat v1.1 gsm shield. it is a wonderful shield but i lack understanding on it. i want to activate a relay via a particular SMS. for example, when i SMS "on" a Pin on arduino will be HIGH and vice versa.
i tried modifying a code, but the result is every time The GSM receives ANY SMS, the pin will be high. can someone assist on making the SMS more specific?
Quote
/* GSM Shield example
created 2011
by Boris Landoni
This example code is in the public domain.
http://www.open-electronics.org
http://www.futurashop.it
int led = 13;
#include <SoftwareSerial.h>
#include <GSM_Shield.h>
char number[]="+39123456789";  //Destination number
char text[]="hello world";  //SMS to send
byte type_sms=SMS_UNREAD;      //Type of SMS
byte del_sms=0;                //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0;    //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
  Serial.println("system startup");
  gsm.TurnOn(9600);          //module power on
  gsm.InitParam(PARAM_SET_1);//configure the module
  gsm.Echo(0);               //enable AT echo
  char inSerial[5];
  int i=0;
  delay(2000);
    Check_Call(); //Check if there is an incoming call
    Check_SMS();  //Check if there is SMS
    //Check data serial com
    if (Serial.available() > 0)
       while (Serial.available() > 0) {
         inSerial=(Serial.read()); //read data
         i++;
       inSerial='\0';
      Check_Protocol(inSerial);
void Check_Protocol(String inStr)
       Serial.print("Command: ");
       Serial.println(inStr);
  Serial.println("Check_Protocol");
    switch (inStr[0])
       case 'a' :  //Answer
           if (gsm.CallStatus()==CALL_INCOM_VOICE){
             gsm.PickUp();
             Serial.println("Answer");
             Serial.println("No incoming call");
       case 'c': // C  //Call
         if (inStr.length()<2)  //To call variable 'number'    comand   c
           Serial.print("Calling ");
           Serial.println(number);
           gsm.Call(number);
         if (inStr.length()==2)  //To call number in phone book position   comand   cx where x is the SIM position
             error=gsm.GetPhoneNumber(inStr[1],number);
             if (error!=0)
               gsm.Call(number);
               Serial.print("No number in pos ");
               Serial.println(inStr[1]);
       case 'h': //H //HangUp if there is an incoming call
         if (gsm.CallStatus()!=CALL_NONE)
           Serial.println("Hang");
           gsm.HangUp();
       case 's': //S //Send SMS
         Serial.print("Send SMS to ");
         error=gsm.SendSMS(number,text);
         if (error==0)  //Check status
             Serial.println("SMS ERROR \n");
             Serial.println("SMS OK \n");
       case 'p':  //Read-Write Phone Book
         if (inStr.length()==3)
           switch (inStr[1])
             case 'd':  //Delete number in specified position  pd2
               error=gsm.DelPhoneNumber(inStr[2]);
               if (error!=0)
                 Serial.print("Phone number position ");
                 Serial.print(inStr[2]);
                 Serial.println(" deleted");
             case 'g':  //Read from Phone Book position      pg2
               error=gsm.GetPhoneNumber(inStr[2],number);
               if (error!=0)  //Find number in specified position
                 Serial.print("Phone Book position ");
                 Serial.print(": ");
               else  //Not find number in specified position
                 Serial.print("No Phone number in position ");
                 Serial.println(inStr[2]);
             case 'w':  //Write from Phone Book Position    pw2
               error=gsm.WritePhoneNumber(inStr[2],number);
               if (error!=0)
                 Serial.print("Number ");
                 Serial.print(number);
                 Serial.print(" writed in Phone Book position ");
               else Serial.println("Writing error");
    delay(1500);
    return;
void Check_Call()  //Check status call if this is available
     call=gsm.CallStatus();
     switch (call)
       case CALL_NONE:
         Serial.println("no call");
       case CALL_INCOM_VOICE:
         gsm.CallStatusWithAuth(number_incoming,0,0);
         Serial.print("incoming voice call from ");
         Serial.println(number_incoming);
       case CALL_ACTIVE_VOICE:
         Serial.println("active voice call");
       case CALL_NO_RESPONSE:
         Serial.println("no response");
     return;
void Check_SMS()  //Check if there is an sms 'type_sms'
     char pos_sms_rx;  //Received SMS position
     pos_sms_rx=gsm.IsSMSPresent(type_sms);
     if (pos_sms_rx!=0)
      digitalWrite(led, HIGH);
  delay(5000);
  digitalWrite(led, LOW);
//Read text/number/position of sms
       gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
       Serial.print("Received SMS from ");
       Serial.print(number_incoming);
       Serial.print("(sim position: ");
       Serial.print(word(pos_sms_rx));
       Serial.println(")");
       Serial.println(sms_rx);
       if (del_sms==1)  //If 'del_sms' is 1, i delete sms
         error=gsm.DeleteSMS(pos_sms_rx);
         if (error==1)Serial.println("SMS deleted");
         else Serial.println("SMS not deleted");
     return;
Federico_Vanzati
sorry but this board of the forum is dedicated only to the official Arduino GSM shield (http://arduino.cc/en/Main.ArduinoGSMShield).
I moved the discussion in the proper section (Networking, Protocols, and Devices).
F
pylon
Please edit your post and use code tags and not quote tags. Without this change your code is modified by the forum system and not displayed correctly and I don't want to guess where you may have had what differently than displayed.
