Thank you very much guys =)
DVDdoug, I haven't found something specified like that... Thank you very much, now I have an idea how to make a file with that extension. About the 12 bit it won't be an issue because as Tuttut's said it store in a 2 byte variable (although it uses only 12 bits); I don't know either if 10khz is a standard fs, but I'm pretty sure that won't be an issue (I've worked with a lot of samples of .wav files and I have downsampled it to so many rates). I'm gonna start to work on this tomorrow and will post the results. Thank you, you were very helpful =)
Tuttut, I didn't know that was some sw that could do something like that... I'll try to use it and then if it works I'm gonna try to make my own conversion (now I know how to procced with the header). Thank you for your help =)
You guys have enlightened me... Thanks once again!
Cheers
