PIN10 an PB2
Chat server address:0.0.32.0
Chat server address:0.0.240.4
Chat server address:2.0.32.0
Chat server address:0.0.0.4
Chat server address:0.32.0.32
Chat server address:0.32.0.4
Chat server address:0.4.0.4
Chat server address:4.0.0.4
Chat server address:255.255.0.4
Chat server address:0.32.0.0
Chat serverÿChat server address:0.4.16.4
Chat server addressChat server address:0.0.32.0
Chat server address:0.32.0.3Chat server address:0.0.0.4
Chat server address:0.37.0.32
Chat server address:2.0.16.16
We have a new client
Chat server address:85.0.32.0
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,178, 177);
IPAddress gateway(192,168,178, 1);
IPAddress subnet(255, 255, 0, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
// initialize the ethernet device
// start listening for clients
server.begin();
Serial.print("Chat server address:");
Serial.println(Ethernet.localIP());
// wait for a new client:
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
// clead out the input buffer:
client.flush();
Serial.println("We have a new client");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0) {
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
PIN10 an PB4
Chat server address:255.255.255.255
Chat seòChat server address:255.255.255.255
