Topic: [SOLVED] EAGLE question: can I reconnect a net to another net (Read 2896 times) previous topic - next topic
liuzengqiang
Mar 22, 2013, 04:20 am Last Edit: Mar 26, 2013, 07:04 pm by liudr Reason: 1
Here is my question:
I draw up a net (say Net1). I then connect it to a net D2. I later decide I want to use D3 instead. I check on the wires on the original Net1 and all of them are connected to D2. Is there a simple way to draw a net, connect it to say D2 and then easily connect it to D3? Thanks.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
oscar_barajas
Using the NAME and LABEL commands could really simplify your schematic connection process and it makes it really easy to  change a whole group of nets and connect it to another pin of an IC for example, look here for more info about EAGLE commands.
http://web.mit.edu/xavid/arch/i386_rhel4/help/24.htm
liuzengqiang
Thanks. But does renaming a wire combine the old net with the new? I'll give it a test.
CrossRoads
Yes, renaming a wire connects the nets.  You can rename a single segment, or all segments of the net.
liuzengqiang
OK I guess I was too cautious then. When I select a segment that is on the D3 net and try to name it D4, I always saw message such as "connecting D3 to D4?" and I back away thinking that I would connect these two nets together and make a mess. Today I got over my fear and tested the rename only this segment and it worked. They should have really say something different, like "disconnecting the current segment FROM D3 and reconnecting it to D4?".
Thanks guys!
skyjumper
The Eagle messages can be a bit confusing, but what's to fear? Just back up the files before you make the change so you can revery back if you mess it up.
CrossRoads
