Topic: Boolean memory size (Read 5567 times) previous topic - next topic
Steen
Hi
I was wondering if a boolean gets saved as one bit, or as a full byte. Since it makes a huge difference in memory usage, but I don't know if the arduino is able to address only on bit. So if you'd save 8 booleans, that would still only take up 1 byte instead of 8 bytes, or is this false?
Thanks
JosAH
A boolean takes up one byte in C++ (zero or not zero for false/true); you can use bit fields in C/C++ that take up single bits; eight of them (one bit each) take up a single byte again.
kind regards,
Jos
gutbag
Try something like:
Serial.print(sizeof(boolean));
This will print the number of *bytes* used for booleans.
Steen
kind regards,
Jos
Well that was the alternate way I'd do it, just generate one bit booleans myself, thanks.
MarkT
bit fields work in structs, each _individual_ variable must be addressable and thus is at least a byte (the unit
of addressing).
majenko
Don't forget to pack your structs so that they take up the least space possible.  I also tend to unionise my bitfields so I have a handy byte / int / etc for setting them / clearing them en-masse:
Code: [Select]
struct flags {
  union {
    unsigned char value;
    struct {
      unsigned on:1;
      unsigned error:1;
      unsigned ping:1;
      unsigned rate:3;
      unsigned size:2;
} __attribute__((packed));
struct flags f;
f.on, f.error, f.ping will all take a 0 or 1, f.rate will take a number between 0 and 7, and f.size will take a number between 0 and 3 - and all in the space of a byte which can be accessed as f.value.
