Topic: What's The Difference?!?! (Read 4529 times) previous topic - next topic
Jeremy1998
I would be pulling my hair out over this, if it was long enough...
I am looking on DigiKey for a Sanguino compatible ATMega 644... I know that I need the 644P... There are 3, and all of the specs are EXACTALLY the same!
They are:
ATMEGA644PA-PU
ATMEGA644P-20PQ
ATMEGA644P-20PU
I would guess the ATMEGA644P-20PU, but I'm not sure, so I thought I'd ask...
keeper63
#1
Jan 10, 2011, 04:11 am Last Edit: Jan 10, 2011, 04:15 am by keeper63@cox.net Reason: 1
I think that's right - the first one would also be OK likely, but the PA (IIRC) means "automotive temperatures" or something like that (able to survive the extremes of that environment). The PU (once again, IIRC) means "DIP" package, while PQ means the QFP-style package (SMT).
I think.
[edit]
Hmm - now that I look at Digikey, what I said above likely isn't correct...though I still think the one you are talking about is likely the one needed...[/edit]
jezuz
#2
Jan 10, 2011, 04:12 am Last Edit: Jan 10, 2011, 04:14 am by jezuz Reason: 1
Last digits/letters often define packaging (not package type, but weather it comes in a roll on in a box or whatever) type. If you look closely in the datasheet, the difference will be pointed out somewhere. Generally, this won't make a lick of difference for a hobby user - it's really meant for mass-production companies who require specific methods of setting the IC's into their machines.
The PA might refer to a different temp spec or something of that sort (I know some chips have a military variant that has different temp/pressure/etc standard and have a similar addition in their part number) - but to be sure look over the datasheet. Be smart tho - use cntrl-f to find the specific sections that refer to variations.
//edit
Also, it could be package variations as well. DIP/QFTP - should also be mentioned in the datasheet.
//edit #2
damn you crosh.
keeper63
darn you crosh.
Don't be so quick - I am pretty certain I am wrong - check on digikey, lookup ATMega644, then select the filter for DIP - then be confused like I am!
;D
jezuz
Well, datasheet says that AU = TQFP; PU = PDIP; MU = VQFN
The A vs PA in the datasheet isn't made clear... I couldn't find it atleast. Probably it's a different of temp ranges or something, b/c the other stats for the two variants seem to be the same.
Jeremy1998
The temps are all the same and they are all DIPs. I just need a 644P... Tell me what to get.
mowcius
ATMEGA644P-20PU
If they're all the same price then you can't go wrong with that one.
