Topic: MEGA 2560 Tone conflict width PWM (Read 7931 times) previous topic - next topic
nickgammon
I've turned the fiddling around with registers into a library.
http://www.gammon.com.au/Arduino/TonePlayer.zip
Now you can just use that:
Code: [Select]
#include <TonePlayer.h>
int Hz = 0;
int prevHz;
TonePlayer tone5 (TCCR5A, TCCR5B, OCR5AH, OCR5AL, TCNT5H, TCNT5L);
  pinMode (46, OUTPUT);  // OC5A
  Hz = analogRead (14) - 300;
  if( Hz < 10 )
    Hz = 33;
  if( Hz > 5000 )
    Hz = 5000;
  if ( abs (Hz - prevHz) > 5 )
    tone5.tone (Hz);
    prevHz = Hz;
    }  // end of frequency change
  }  // end ofloop
It supports Timers 1, 3, 4, 5. (The Uno only has Timer 1 out of that lot). The comments in the library show how to use the other timers.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
sldiesel
#16
Apr 01, 2013, 06:09 pm Last Edit: Apr 01, 2013, 06:51 pm by sldiesel Reason: 1
Code: [Select]
int Hz = 0;
int prevHz;
 if( Hz < 10 )
   Hz = 33;
 if( Hz > 5000 )
   Hz = 5000;
   tone5.tone (Hz);
   prevHz = Hz;
 }  // end ofloop
Hi I have just implemented that in my code and now have a rock solid TACHO driver.
I think that this tread can be useful for many people. having problem width timers on the Mega
I must say i have newer expected to get that kind of help in a Forum, Thanks alot.
Here is a video of it working
http://www.youtube.com/watch?v=Gh-9Jlec8E8
embeddeddummies
Just wanted to give proof that this is still useful after all those years. It really saved my day, going from 'What the hell?!?!' directly to 'Eureka'! ;-D
Two thumbs up!!!
