Topic: Flow meter (Read 4536 times) previous topic - next topic
07clarkesm06
I am trying to build a prototype with an arduino and a flow meter, I have used the link below to show me how to build all of it. I have uploaded the script fine and built the circuit according to the diagram but when I open the serial monitor and put a flow through the flow meter the reading does not change, it stays at 0 L/hour. Any ideas why it is not picking up any readings?
http://arduino.cc/forum/index.php/topic,8548.msg69407.html#msg69407
volatile int NbTopsFan; //measuring the rising edges of the signal
int Calc;
int hallsensor = 2;    //The pin location of the sensor
void rpm ()     //This is the function that the interupt calls
  NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
// The setup() method runs once, when the sketch starts
void setup() //
  pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
  Serial.begin(9600); //This is the setup function where the serial port is initialised,
  attachInterrupt(0, rpm, RISING); //and the interrupt is attached
// the loop() method runs over and over again,
// as long as the Arduino has power
void loop ()
  NbTopsFan = 0;      //Set NbTops to 0 ready for calculations
  sei();            //Enables interrupts
  delay (1000);      //Wait 1 second
  cli();            //Disable interrupts
  Calc = (NbTopsFan * 60 / 7.5); //(Pulse frequency x 60) / 7.5Q, = flow rate in L/hour
  Serial.print (Calc, DEC); //Prints the number calculated above
  Serial.print (" L/hour\r\n"); //Prints "L/hour" and returns a  new line
Thanks
Sarah
Magic
Hi Sarah
To me the sketch looks ok but looking at the breadboard in Your link it seems to me that the yellow wire (signal) is connected to the positive rail ?
Magnus
07clarkesm06
Hi Magnus
I've attached pics of my breadboard, do you think something needs to be moved then?
Thanks
Sarah
Riva
As Magic says the Fritzing image does not look right. Ground (Black) from the sensor is connected to nothing. VCC (Red) is connected to arduino ground and Signal (yellow) is connected to arduino 5V.
Try connecting the Red & Black sensor wires directly to the relevant breadboard power rails and the yellow sensor wire direct to the relevant end of the resistor on the breadboard.
Don't PM me for help as I will ignore it.
07clarkesm06
Thank-you both so very much! It worked straight away once I changed the wires around.
Sarah
